10-10-2018
19:21
15:03
10-10-2018
19:21
15:03
Hi,
I have the Fitbit charge 3 and I installed the Fitbit application on my android phone. The application keeps showing a notification mentioning "Connected GPS is running".
Is it a normal behavior?
Is it possible to remove the notification?
Thanks
Hey there @Toé, it's nice to see you around here! Charge 3 includes connected GPS. This means that it will connect to the GPS through your phone. Connected GPS is available for all supported phones with GPS sensors. For more information about setting up connected GPS; check this helpful article.
Please check Charge 3 User Manual (page 36) for information on tracking GPS exercises with this new device.
Hope this helps. Keep me posted! ![]()
Best AnswerI have the same problem. connected gps always running even when no exercise activity is in process .the location icon on Android is also illuminated showing it is actually on . this just started this morning. how do I turn off the fitbit connected gps? using pixel 3 with all latest os updates .
I think I figured out how to stop this. I have a Charge 3 and on the watch auto-recognizes some exercises. Swipe right to see the exercise menu. Then edit each exercise to turn off "use connected gps." I think what has been happening is it is trying to auto-recognize my treadmill activity but becuase it is indoors it doesn't work... and then it fails to disconnect the gps after the activity is finished.
After disabling "use connected gps" in each of the auto-recognized activities the "connected gps running" notification went away and was replaced by the normal "syncronization" persistent notification. Unfortunately I didn't figure this out until my batter was nearly dead!
Same problem here. My phone was showing "Connected GPS is running" all the time and this was killing my phone battery.
I had to unckeck all activities so they don't use GPS to fix that.
I think there is a bug here!
I have the same problem but even with all exercises turned off I still have "Connected GPS is running". It updates constantly, even when sitting still! DRAINING my phone battery! It's down 7% in 5 minutes (since I took it off the charger.)
What else can I do?!
Best AnswerThis didn't work for me. I still get GPS not connected in the app and no gps icon appears on the charge 3. Is there something specific for Motorola phones?
Best AnswerHi I just gotten my Fitbt Chrage 3. Quick Q on GPS.
Assuming I turned on GPS for running and my phone is not with me. Will the Fitbit 3 auto synced up the GPS map once its connected when I am near my phone thereafter?
Best AnswerNo this would not work. This is because all GPS data comes from your phone as the Charge 3 does not have it's own inbuilt GPS. It needs to talk to your phone on the journey.
Best AnswerNot working for me either and I have a samsung. It started after the latest Ed updates
