02-27-2021
08:04
03:29
WilsonFitbit
02-27-2021
08:04
03:29
WilsonFitbit
I can’t log anything on my dashboard yet it’s syncing fine.
Trying to tap on each one but nothing?
03-01-2021 03:28
03-01-2021 03:28
Hello @Loucharlo, it's great to see you around! @LZeeW, I am also glad to see you around and thanks for your input!
@Loucharlo, thank you for resolving this inconvenience! I was able to see that @LZeeW also provided some instructions in order to fix this inconvenience. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Have a great day!
Best Answer02-28-2021 06:35 - edited 02-28-2021 06:36
@Loucharlo It sounds like you are having problems with the Fitbit app. Try the following
Laurie | Maryland
02-28-2021 09:07
02-28-2021 09:07
Thanks. I managed to sort it myself. It needed the app deleting and reinstalling in the end. 👍
03-01-2021 03:28
03-01-2021 03:28
Have a great day!
