12-27-2019
16:46
10:29
12-27-2019
16:46
10:29
My Charge 3 battery dies daily. I fully charge it and it is dead by night. Is this normal? Can I order a replacement battery?
12-28-2019 08:59
12-28-2019 08:59
Hi there @TarynAnn, welcome to the Community Forums. Thanks for the details provided about your Charge 3's battery behavior.
As per the description, it seems that it has insufficient power source. Where do you charge your tracker? Have you checked if by any chance the USB port or outlet is faulty? If you haven't done so, try a different port. A UL-certified wall charger will also work. Don't use a USB hub. You can find more detailed information in the help article: Why isn't my Fitbit device's battery charging?
Also, I'd like you to review the tips and recommendations provided in the article: Can I extend my Fitbit device's battery life?
As a friendly reminder, the following are some factors that have an impact on battery life and may cause your battery to drain more quickly:
If you still believe your battery is not lasting as long as expected, we’d like you to do a battery test to see how long your battery lasts after a full charge. Please do the following:
Let me know how it goes, I'll be around and glad to further assist you.
Best Answer12-28-2019 08:59
12-28-2019 08:59
Best Answer12-28-2019 13:32
12-28-2019 13:32
Best Answer12-30-2019 11:29
12-30-2019 11:29
Hello there @TarynAnn, thanks for getting back and letting me know the outcome. I'm sorry for the delayed response.
Since none of the steps recommended have worked, I went ahead and created a case for you with our Support Team. Someone will reach out to you soon to offer their assistance. Please keep a lookout in your inbox to the email address associated with this account.
Let me know if there's anything else I may do to help you in the meantime.
Best Answer12-30-2019 12:03
12-30-2019 12:03
Exactly the same thing happens to me. I fully charged by Charge 3 yesterday - 3 times! And it went to dead very quickly. I fully charged it before bed and it was turned off by the morning. I’m so disappointed as all my stats are not accurate now. Please help me, it has been an ongoing issue for some time.
12-31-2019 04:58
12-31-2019 04:58
I am so disappointed with the charge 3. My first one ended up with white lines through the screen and now this one won’t charge.
I upgraded to the Charge 3 thinking it would be better than the Flex and Flex 2, but I totally regret it. Waste of money.
Best Answer12-31-2019 05:43
12-31-2019 05:43
Hello @Diditowns, welcome on board. I totally understand how you feel. I was about to create a support case on your behalf, but I've seen you contacted our Support Team after posting here and that they have helped you with this. Please make sure to reply back to your case after performing the battery test they recommended.
Hi @TarynAnn, thanks for getting back. I am sorry to hear that you are going through this situation. I appreciate your feedback for the Fitbit trackers.
Please note that our main purpose is to avoid negative experiences to our customers, we're always willing to help and provide troubleshooting steps. Then, if the tracker is deemed defective we review eligibility using the one year warranty option.
Additionally, our products are indeed designed and made to last (this goes for each product component) however, there is not an infallible way to ensure that no issues will be present in the long run. Because of this, our Warranty Policy is set into providing as much coverage as we can.
I created a support case on your behalf the last time you posted here. Please stay tuned to your inbox, someone will contact you shortly.
Let me know if there's any questions present.
Best Answer01-12-2020 14:52
01-12-2020 14:52
My battery shows 100percent in Morning, 60percent at night and dead by next afternoon. i tried your recommendations and still the same outcome less than 2 days use on a charge, it lasted more than 7 days on a charge before 2 weeks ago then over night 2 days on a charge and now less
Best Answer01-13-2020 08:59 - edited 11-27-2023 06:10
Hello @Dazgremlin69, welcome to the Community Forums. Thank you so much for the details provided and for taking the time to follow the tips and recommendations I provided above.
Since this sounds a bit more serious, I've created a support case on your behalf - you should soon receive an email from Customer Support at the email you used to register with the Community forums. If you have any questions, don't hesitate to let me know. 😉
Best Answer07-08-2020 03:39
07-08-2020 03:39
My charge 3 battery has been draining very quickly for the past week. It use to last up to seven days. I did not change my usage and have been using the same wall plug in for the past two years. But now I can’t even keep it alive 24 hours it is very disappointing.
08-20-2022 08:33
08-20-2022 08:33
omg, I went through the same exact issues!!
first charge 3 had the white lines
now this charge 3 is dying before the day even ends
Best Answer12-07-2022 22:47
12-07-2022 22:47
As a friendly reminder, the following are some factors that have an impact on battery life and may cause your battery to drain more quickly: Frequently checking the Fitbit app, which syncs your tracker. Frequently receiving notifications. Frequently checking your stats.
Regards
