02-23-2022 16:52
02-23-2022 16:52
My Charge2 stopped syncing since yesterday morning. Tried all suggested by Fitbit support- Bluetooth on/off, unpair/pair, reinstalled app, re-setup device etc etc...nothing works. Final word from support was - your product is out of warranty!!!
Steps seem to be transferring to the app, but nothing else. Also not syncing to the server
Anyone else having similar issues?
Or any out of the box solution please??
02-24-2022
05:59
08:31
02-24-2022
05:59
08:31
Thanks for getting back to us and for following suggested steps to sync your Charge 2 @BRohit.
I sent you a PM in order to continue assisting you.
Keep on visiting the forums.
08-01-2022 13:22
08-01-2022 13:22
Mine has stopped syncing since 21st July, app updated with new screens on dashboard, nothing new tracked all week. Have you resolved?
08:13
04:39
08-02-2022
08:13
04:39
Welcome to the Fitbit Community, @MillieMandy. Thank you for letting us know that your Charge 2 stopped syncing since July 21st.
Could you please confirm that you have followed the instructions of help article: Why won't my Fitbit device sync?
Best Answer08-02-2022 08:23
08-02-2022 08:23
Hi there.
I did try all the uninstall/install, reset instructions etc nothing worked.
Eventually I worked out that the issue was the wifi network I was logged into. For some reason the network was not allowing connection to the fitbit servers, everything else was working fine. Logging onto an alternate network made the tracker sync immediately.
Infact using a VPN with the first wifi network worked as well.
I am not a tech persion so can't tell you why or why not.
Hit and trial.
Hope this helps.
08-02-2022 11:09
08-02-2022 11:09
I have the same problem. it’s stuck on logo with version and batthery icon. it wont turn on and wont sync.
08-02-2022
14:12
04:40
08-02-2022
14:12
04:40
Thanks for getting back to us and for your advise @Redsainte.
Welcome to our community @Redsainte. Have you tried restarting your tracker?
Best Answer08-03-2022 03:22
08-03-2022 03:22
Best Answer08-03-2022 03:25
08-03-2022 03:25
08-03-2022 06:34
08-03-2022 06:34
Hi.
Try connecting via your cell phone's mobile data or log into a different wifi network.
Cheers.
08-04-2022
06:04
04:40
08-04-2022
06:04
04:40
Best Answer08-07-2022 04:42
08-07-2022 04:42
11:49
04:40
08-08-2022
11:49
04:40
Thanks for getting back to us @BRohit.
I'm sorry you've had this experience and just to confirm, did this happen while access your account in the Fitbit app or online dashboard? I'm asking this as the issue seems to be related to your IP address and usually should resolve within 48 hours. If after that time frame the issue persists, please reply back with a screenshot of the error message displayed so I can investigate on my end.
Best Answer08-08-2022 21:06
08-08-2022 21:06
07:05
04:40
08-09-2022
07:05
04:40
Thanks for getting back to us and for letting us know that your access restored now @BRohit.
Sometimes this happens but, as mentioned before, it gets resolved within 48 hours.
12-07-2022 22:51
12-07-2022 22:51
To sync your Charge 2, tap the Account icon in the upper-left corner. Tap your Charge 2 under Devices. Under Sync, tap Sync Now to sync your Charge 2 manually, or tap All-Day Sync to synchronize your Charge 2 in the background at intervals throughout the day.
Regards,
Will
