Charge 3 battery draining
My Fitbit Charge 3 is 1 year old, and my battery started acting weirdly. It lasts max 4 hours. I have followed all the steps suggested in this forum. What should I do?
6 REPLIES 6
Welcome to the Forums, @Sergioba05.
Thanks for troubleshooting this battery issue. If your Charge 3 isn't holding a charge, I recommend taking a look at the help article: Can I extend my Fitbit device's battery life? and make sure you have followed the tips provided there.
Let me know how it goes. 🙂
Thanks, Alejandra. I will.
Mine started draining yesterday.  I have done all the recommendations. I charged it one hour ago completely and it’s now at 69%. Frustrating.  Don’t know what to do
Yes, it is frustrating. I have followed the instructions on the article, but it has lost 17% in an hour, so it's not going to make till the end of the day.
I just called for a replacement.  I got this as a bday present in 6/2019 and this is the second time I have had it replaced!  It’s still under warranty.  I do not recommend a fit bit
Sent from Yahoo Mail for iPhone
Your suggestions worked for a couple of days, and then it died completely. Last time I buy Fitbit! In one year it was replaced, and it's not working any longer!
