07-24-2020
16:06
13:17
07-24-2020
16:06
13:17
Yesterday my Fitbit went black screen. Did the tips I saw To plug in and press side for 8 seconds to reset. It would only vibrate for 5 seconds and not reset. I tried to change the clock face like I saw Posted but my Bluetooth will not connect to phone. This morning the my Fitbit started to vibrate randomly while sitting on my night stand. What is going on? It was working perfectly and now nothing
07-25-2020 05:59
07-25-2020 05:59
Hi there @mldcabrera, welcome to the Community Forums. I'm sorry to hear that you went through this situation with your Charge 3's display.
I appreciate you have already tried to troubleshoot this situation before reaching us. At this moment, I’ve reached the limits of what I can do for you here on the public community forums, so I've contacted our Support Team on your behalf to look into this issue further and provide you with some options. Please keep an eye on your email inbox for further instructions. Note that due to recent events affecting our operations, support options are limited and wait times are longer than usual.
We hope your issue is solved soon.
07-25-2020 06:20
07-25-2020 06:20
I am having the same problem and have also tried the suggested fixes. Looking for a resolution. Thank you.
07-25-2020 07:51
07-25-2020 07:51
Hi there @Peregrine75, welcome on board. Thanks for the details provided in your post and for taking the time to follow the tips and recommendations provided in the Community Forums. Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
Best Answer07-26-2020 11:12
07-26-2020 11:12
It happens the same to me. It started to vibrate by itself, and later on, the screen became almost dar.
I can see letters, but it is to deem to use it. I restarted my Charger 4, and still, I don't get it working.
Should I through it just like another piece of garbage. It cost me $200 two months ago.
Best Answer07-26-2020 11:15
07-26-2020 11:15
Mine is charge 4 and it is exactly the same, The screen is almost black the watch lost its brightness.
Should I through in the garbage? $200 and two old months
Best Answer07-26-2020 12:39
07-26-2020 12:39
Not only on charge 4, it is happening on the charge 4 too.
Best Answer07-26-2020 12:57
07-26-2020 12:57
I have exact same issue with my Charge 3. Screen started to flicker and vibrate for some minutes, then all went black, and can not be synched anymore. I have tried all tips and tricks (not able to get it to restart, although charged).
Do I need to scrap it?
Best Answer07-26-2020 13:08
07-26-2020 13:08
Same issue with mine as well. It worked this morning until approximately 10:53 AM MST and then the screen went blank. It vibrates when I press the side, but no display. Tried all the restart instructions for the Charge 3, but it only vibrates and doesn't restart.
07-26-2020 14:24
07-26-2020 14:24
I’m having the same problem with my charge three. I thought the battery had died when I went camping. So I put it on the charger For awhile and the only thing it will do is vibrate if I hold the side. But I’ve tried resetting it and it will not respond to that at all. No response on the screen and it will stop vibrating after 9-12 seconds.
it’s not syncing to my phone at the moment either.
Best Answer07-26-2020 14:31
07-26-2020 14:31
I’ve just got a blank screen and vibrating when buttons pressed but no reset and won’t connect to phone
07-26-2020 14:54
07-26-2020 14:54
Hi, I'm having the same problem with my charge 3 too. Have tried the hard switch off and on, but no display at all now!
Best Answer07-27-2020 00:28
07-27-2020 00:28
Update on my issue. I let the Charge 3 be over night and during morning battery was run out. I was able to charge a little bit, and even restart (also getting the smile symbol on display). However, after that, just a single grey line crossing the display. Still not able to synchronize or start.
It might also be worth mentioning, the diods on the back (towards the skin) is all black as well.
Any ideas?
07-27-2020 11:55
07-27-2020 11:55
Seems that a lot of customers are having the same or similar issues with the Charge 3. Mine started to vibrate this morning while sitting on my desk by itself. I tried again all the restart options and nothing worked so last night I unplugged it from my computer and left it. This morning when it started to vibrate by itself, I tried to restart it again, now it doesn't vibrate anymore, but still isn't working. No one answers at the call centre. I know they are busy, but not everyone has time to wait. Since there seems to be so many people experiencing the same thing, is this a network issue?
Best Answer07-27-2020 14:09
07-27-2020 14:09
I’m having the same issue - no disk-lay for almost a week. The random vibration just started and I have gone through all the restart steps and no display
07-27-2020 14:46
07-27-2020 14:46
My Fitbit is doing the same thing. I upgraded from a charge 2 to a charge 3 just a few months ago and it won’t turn on now- screen is blank and just vibrates. I have tried all the steps to get it to come on that I saw suggested and nothing. It’s a bit frustrating as I never had problems with the charge 2 - any suggestions??
Best Answer07-27-2020 16:23
07-27-2020 16:23
The same thing has happened to me. After being on a chat with Fitbit, they determined that the Charge 3 is faulty. Of course it is over the warranty, so they said they would give me a discount on a new one. that is bull**ahem**. they make junk stuff. I would say go get something better. This is the second Fitbit I have had that crapped out after two years.
07-27-2020 16:53
07-27-2020 16:53
Thanks @jimfehr that was very helpful. Mine is 1 1/2 years old so it might be covered. My Fitbit One lasted longer than this one. And I agree, offering a discount is pretty minimal and not enough to invest more $$$ for it only to die within 2-3 years. I wonder why this model is still being sold if so many are faulty....
07-27-2020 18:53
07-27-2020 18:53
07-28-2020 04:55
07-28-2020 04:55
Thanks again @jimfehr . When I went to the warranty page, I read 2 years but I think that is only if I had bought the extended warranty, which I didn't think I would need.
However, that being said, I woke up this morning to my Fitbit working. I decided to keep it plugged in for the night, since I hadn't tried that. When I woke up this morning, I did the restart again, and it booted up. It's been almost 2 hours and it is still working but not sure I trust it will stay that way. It is also syncing again with my dashboard.
