Charge 3 blank screen
ANSWERED
All of a sudden the Fitbit keeps vibrating then the screen keeps switching between clock face and the notification screen. I tried to do a restart and the screen just went blank and now does nothing. Tried the long re-boot but all it does is a long vibration when I press the side button and then nothing? Any assistance would be appreciated. It is only 1 year old. As it was a gift I don't have the receipt either.
1 BEST ANSWER
Accepted Solutions
Thanks for the update, @Sparrow22.
Since the instructions provided didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
In the meantime, let me know if you need anything else. 🙂
5 REPLIES 5
Welcome to the Forums, @Sparrow22.
I appreciate all the efforts in trying to fix this display issue. If your tracker isn't turning on, I recommend taking a look at this post and make sure you have followed all the steps provided there.
Let me know the outcome. 🙂
Hi AlejandraFitbit
Many thanks for your advice, unfortunately it did not fix the issue. The screen is still blank and when the button on the side of the Fitbit 3 is depressed it does a long vibrate then nothing 😞
Is there anything else I can try??
Kind Regards
Sparrow22
Thanks for your assistance AlejandraFitbit, I really appreciate your help! Cheers Sparrow22
You are welcome, @Sparrow22. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up! 😉
