01-24-2020
04:44
17:35
01-24-2020
04:44
17:35
I had my Charge 3 for 10 days, it was working perfectly till this morning.
Around 5:30 am I synced it and since than it has gone blank and App does not find the device anymore.
I have try to restart it .. did not work !!!
Any suggestions??
Thanks in advance,
Yappi
01-25-2020 05:18
01-25-2020 05:18
HI there @Yappi29, welcome to the Community Forums. Thanks for the details provided about your Charge 3's screen behavior and for trying to fix it prior to contacting us.
I've seen you contacted our Support Team after posting here and that they have helped you with this. Please keep an eye on your inbox for updates on your case.
Let me know if there's anything else I may do to help you in the meantime.
Best Answer01-28-2020 04:58
01-28-2020 04:58
It was not possible to fix the issue, therefore I was offered a replacement which I will be receiving today.
Hopefully the new one won’t have any default so that I can carry on enjoying my new fitness tracker.
01-28-2020 09:26
01-28-2020 09:26
Hi @Yappi29, I'm glad to hear that you're receiving your replacement today.
Don't forget that you can set up your new Charge 3 on your currently without losing any previous data by following the steps below:
I'll be around if you have any questions.
