02-02-2020
06:19
17:16
02-02-2020
06:19
17:16
I was tring to turn up brightness of screen in setting when it gone to no back light and cant see info on screen to turn back on.How do I turn it back on when I cant see screen because I cant find option in app to do so
Thanks kiltevg5
Hi there @Kiltevg5, welcome to the Community Forums. Thanks for the details provided about your Charge 3's blank screen, I'll be glad to help you.
As my friend @cbwilsha recommended, please restart your Charge 3. If the restart doesn't work, I suggest restarting your Charge 3 using the 15-second method:
In case that neither of the restarts work, please check in your Fitbit app if your Charge 3 is still syncing. If so,change the clock face to a different one to see if this brings back the display. Don't worry if you cannot see anything on the display by now, this process is done through the Fitbit app.
To adjust the brightness on the Fitbit Charge 3, go into the Settings on your tracker, find the brightness setting, and tap to change it (Normal, Auto, Dim).
