Charge 3 blank screen
I just bought a brand new Charge 3, I’ve never used Fitbit before I followed through with the set up instructions and now the screen is black. on the app it is says I have to update the firmware I have selected update over five times every time the screen does a little line across, like it’s updating and then the app tells me it’s finished but then it failed to sync. I think I have a defected device.
1 REPLY 1
Welcome to the Forums, @MonicaCz.
Thanks for troubleshooting this display issue. Upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
In the meantime, let me know if you need anything else.
