04-09-2023
04:57
09:58
04-09-2023
04:57
09:58
I am not able to see charge 3 display on Fitbit
can someone suggest me
how to do it ?
04-09-2023 06:00
04-09-2023 06:00
This is the Charge 5 forum, you can try posting your question in this forum.
Gary D.| Feeding Hills, MA MBG PE
Charge HR, Charge 2, Charge 3, Inspire 2, Charge 4, Charge 5, Pixel Watch 2, Pixel Watch 3
04-09-2023 06:38
04-09-2023 06:38
@Samudrala I moved your post to the Other Charge tracker forum. No need for you to ask your question again.
I apologize if I’m misreading your post. Does your screen respond to tapping or swiping? Have you tried restarting it? Can you describe your issue any other way?
If your screen is dark, no matter what you do, you might have a screen failure. There are other posts in this forum from other users and they had the same issue.
There is a link to Support at the bottom of the page for more help.
Laurie | Maryland
04-09-2023 10:01
04-09-2023 10:01
Hi there, @Samudrala. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 3.
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
@gdio53 @LZeeW Thank you so much for your help and moving the post to the correct board.
04-09-2023
11:46
13:33
WilsonFitbit
04-09-2023
11:46
13:33
WilsonFitbit
My charge 3 screen is blank.
On the app it shows fully charged, I've changed the clock face and placed on charger and done a reset it is still blank HELP
Moderator edit: clarified subject
04-09-2023 16:46
04-09-2023 16:46
I have the EXACT same thing happening to me as well. It JUST started this morning (4/9/23). It was fine! I went to chk on the brightness setting because it seemed like it was little dark and when I got to that screen on the tracker, it went blank and has been blank ever since. It is STILL tracking my steps, syncing, etc., and vibrating when I connect it to the charger or chg the clock face, but NOTHING will display. Can't tell if it's resetting or not because there is no display, but it's definitely vibrating like the reset is working. Can't find a way to reset it from within the app vs on the phone, so I'm pretty sure it's trashed. 😞
04-09-2023 17:35
04-09-2023 17:35
Were you able to get your screen to display? I'm seeing there have been SEVERAL of these "failures" within the past 24hrs. Seems a little odd to be a coincidence!?! None of the "fixes" I've found online have worked for mine. Mine quit this morning (4/9/23) after I went in to the "dimness setting". The screen just went blank, disappeared and will not return. I've tried chg'ing the clock face and doing a hard reset and nothing works. Pretty sure it's a lost cause. 😞 Just seems suspicious, like perhaps a software/firmware update broke all of these Charge 3's.
04-10-2023
18:04
06:36
04-10-2023
18:04
06:36
I cannot read the screen of my Charge 3. I’ve tried all the suggestions in the forums, but nothing has worked. It still counts steps and vibrates when I receive a message or am notified to move.
04-10-2023
19:03
06:36
04-10-2023
19:03
06:36
All of a sudden my screen is black. Still vibrates, charges and tracks fine.
I've tried resetting, I've tried changing the clock face. Both many times in hopes it would work. They do not. Very disappointed 😔
04-11-2023 05:00
04-11-2023 05:00
Yesterday I noticed mine was not very bright and tried making it brighter, but didn’t work. This morning it is totally black.
04-11-2023 14:36
04-11-2023 14:36
Hi everyone! Thank you for your messages and efforts.
If you already tried restarting the Charge 3 and the long restart, please give our team a call or chat with them. They'll be more than glad to provide further assistance.
Click here to get connected.
04-11-2023 22:12
04-11-2023 22:12
Plug the device into the charging cable. While the device is plugged into the charging cable, hold the button down for 15 seconds. Remove your finger from button.
