01-26-2024
09:17
06:07
01-26-2024
09:17
06:07
I can't read the unit's display. Both of my Charge 3's are dark. Did you guys turn them off in an update?
01-27-2024 05:41
01-27-2024 05:41
The same thing happened to mine.
01-28-2024 17:38
01-28-2024 17:38
Same here, can't get anything other than a black screen
01-29-2024 03:22
01-29-2024 03:22
Same with mine. Its so annoying.
01-29-2024 22:33
01-29-2024 22:33
My phone is blank. Updating on the app. Have tried the fixes posted online but they do not work
01-31-2024 14:19
01-31-2024 14:19
Mine too! Doing a long reboot didn’t do anything & I can’t see anything on the screen.
02-01-2024 09:26 - edited 02-01-2024 09:38
Welcome to the forums Everybody.
Thank you for taking the time to share the details about the inconvenience with the devices. Sorry to know the situation.
Please, try to sync the device as indicated here:
1. With your device nearby, open the Fitbit app and tap Today.
2. Press and hold on the screen and pull down.
If your tracker is unresponsive:
In case the device is still having difficulties, please change the clock face.
Best Answer02-01-2024 16:14
02-01-2024 16:14
I’m having the exact same issue and I’ve tried restarting it and changing the clock face and it’s not doing anything
02-01-2024 16:23
02-01-2024 16:23
02-03-2024 05:34
02-03-2024 05:34
I’m having the same problem and on top of that my Charge 3 refuses to sync. I haven’t used it in a year, so I don’t think it’s hardware related
02-03-2024 15:05
02-03-2024 15:05
Same issue. Also I am not able to find option for adjusting the brightness of the screen from the app. It was there earlier.
02-04-2024 14:44
02-04-2024 14:44
Like others I am having the same issue. I've followed the instructions above and it still isn't working
02-04-2024 21:27
02-04-2024 21:27
We’ve all tried your fix and it doesn’t work. Please follow up with your customers and resolve this issue.
02-04-2024 22:03
02-04-2024 22:03
I had that same problem. I tried everything but you can’t do anything when your screen is black. I did the phone trick they said to try and I have NO idea why, but my screen came back. On Fitbit app on your phone go to the today screen where you can see your steps today and then hold and swipe the phone screen down. You will see a progress bar quickly go across the top of your screen and the next time I tried to wake up my phone a minute later, it was back!
Best Answer02-05-2024 18:24
02-05-2024 18:24
02-06-2024 02:10
02-06-2024 02:10
My Charge 4 is also having this problem. I have tried every suggested action and my screen is still blank. It records steps and my heart rate through the app so I know it is still on but I can't read a black screen. I was told we have to go through these steps before they can suggest other steps. Also including cleaning the Fitbit charging parts. I have done that and plugged it in to a different outlet and left it charging for over a half hour. I have tried resetting in multiple times. Yesterday I was at least getting a smiley face after the reset but then just a black screen afterward. Today it is not even showing the smiley face. I am hoping now that I have done every single thing they have suggested they will try to solve the actual issue which has nothing to do with the battery.
02-06-2024 08:41
02-06-2024 08:41
02-06-2024 22:13
02-06-2024 22:13
I have the same problem - blank screen, the Fitbit is recording on the app as normal. All the fixes provided don’t work - now customer support say I need to buy a new one - as mine is out of warranty. My comment that a lifespan of 3 years is very poor is ignored. Why would i buy another one of these???
02-06-2024 22:20
02-06-2024 22:20
Same. Numerous emails and they don't care that I've said I will not buy another fit bit. Very poor customer service. They've basically rendered our products useless so we buy a newer model. They won't accept in emails that it's happening to Numerous customers yet look here we are all having the same problem.
02-09-2024 22:33
02-09-2024 22:33
None of your options are working and it’s not connected to my phone either I need the screen to wake up so I can connect it what’s your go to fix for it have tried the reset but still a black screen?
