04-26-2020
19:01
11:44
04-26-2020
19:01
11:44
Those problems happened without warning. It started with screen flickering. I restarted it and I thought it was OK. Then withen the half hour it started flickering AND vibrating. I restarted it again and just got a horizontal line. So far outside of extreme flickering and vibrating all I've gotten out of my charge 3 is the battery symbol, the happy face, and the horizontal line. Oh sometimes the screen wake and notifications icon keep getting turned odd. No I am not doing it. I have only had this Charge 3 three months.
04-26-2020 20:06
04-26-2020 20:06
Try to change clock face (use the app). It sometimes helps issues like this
Best Answer04-26-2020 21:42
04-26-2020 21:42
My Charge 3 doing same,did u get problem resolved 😖😊Thankyou.
Best Answer04-27-2020 09:46
04-27-2020 09:46
I tried the single piece of advice I got...Changing the clock-face, but it didn't work. The app couldn't connect to the fitbit to make the update. Even though the fitbit was laying on top of my tablet! Notice my Charge 3 is only 3 months old? I am asking for a new one! 8-(
04-28-2020 16:00
04-28-2020 16:00
Best Answer04-28-2020 17:39
04-28-2020 17:39
Mine acted exactly the same way and then just died.
This is the second Fitbit I’ve had now that died within 18 months of purchase. I don’t believe they are built to last.
Best Answer04-28-2020 19:11
04-28-2020 19:11
