04-18-2020
19:57
13:02
04-18-2020
19:57
13:02
My Charge 3 just started to go ballistic. It is literally having a fit. It just started flashing and changing screens for no reason, won't stay on any screen for more that 1-2 seconds and won't stop doing this - even to charge. Because it is doing this constantly, there is no way to stop it or charge it. Just a little over 12 months old - never dropped or put in water. I have ordered a new charger - cheapest way to try something.
Can anyone enlighten me ?
Thanks
Hi there @MAK2822, welcome to the Community Forums. I apologize for delayed response. I'm sorry to hear about your Charge 3's screen odd behavior. Thanks for making sure you haven't dropped it or put in water, I'm here to help you.
If you haven't done so yet, I suggest restarting your Charge 3 by following the steps provided here: How do I restart my Fitbit device?
If the restart doesn't work, let's try restarting your Charge 3 using the 15-second method:
In case that neither of the restarts work, please check in your Fitbit app if your Charge 3 is still syncing. If so, change the clock face to a different one to see if this brings back the display. Don't worry if you cannot do anything with the display now, this process is done through the Fitbit app.
Give this a go and let me know the outcome.
Hello @MAK2822, thanks for getting back and for the update. Sorry for my delayed response.
Please note that our main purpose is to avoid negative experiences to our customers, we're always willing to help and provide troubleshooting steps. Then, if the tracker is deemed defective we review eligibility using the one year warranty option.
Additionally, our products are indeed designed and made to last (this goes for each product component) however, there is not an infallible way to ensure that no issues will be present in the long run. Because of this, our Warranty Policy is set into providing as much coverage as we can.
Since you've ordered a new charger, I'd recommend waiting until it arrives to test your Charge 3 and see where the issue is coming from. If the new charger does nothing to bring your Charge 3's display back, do not hesitate to contact me back and I will be more than glad to move to the next step.
I look forward to hearing from you soon.
