05-21-2019
18:48
11:08
05-21-2019
18:48
11:08
Ive got a line of dead pixels near the top of my screen on a charge 3 that I got last December. I did the reboot from the settings on the device. That did not solve my problem. I then tried to reboot with the device plugged in to the charger, but for some reason it does not seem to be responding to that. I have successfully rebooted it while on the charger before. I also made sure that the battery was fully charged. Any help or suggestions would be appreciated.
05-22-2019 05:15
05-22-2019 05:15
Welcome on board @Brent1987! Thanks so much for the steps you've tried in order to solve the issue with your Charge 3's screen.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon! ![]()
Thanks for your help @NellyG!
Please let us know if there's anything else we may do to assist you in the meantime.
05-22-2019 00:12
05-22-2019 00:12
I have flagged your post for a moderators assistance.
Helen | Western Australia
05-22-2019 03:39
05-22-2019 03:39
I did finally get the tracker to reset while plugged in, but it did not seem to fix the problem either.
05-22-2019 03:41
05-22-2019 03:41
Thank you NellyG
Best Answer05-22-2019 05:15
05-22-2019 05:15
06-12-2019 02:54
06-12-2019 02:54
Hi I am having the same issue. Logged an email case (#30721806) but no response yet
Best Answer06-13-2019 08:30
06-13-2019 08:30
Welcome on board @kerryfalconer! I've seen that our Support Team has already replied to your support case. ![]()
Please let me know if there's anything else I may do to assist you with.
Best Answer07-01-2019 20:18
07-01-2019 20:18
Hi MarreFitbit my charge 3 has dead pixels running vertically and horizontally.
I’ve tried to restart the Fitbit and I’ve tried to change the screen both to no avail.
Thanks in advance.
07-01-2019 23:08
07-01-2019 23:08
I think i am having the same issue. the charge 3 has two black lines on the top. This was given to me as a gift in December.
07-04-2019 08:33
07-04-2019 08:33
Welcome to the Community Forums @El_Rey_de_El_Ay! Thanks for already troubleshooting your Charge 3's display.
Welcome on board @KateYenik! If you're having the same issue with your Charge 3's screen, I'd recommend trying to perform a restart.
If the restart does not work either, please check on the Fitbit app if your Charge 3 is still syncing. If so, change the clock face to a different one to see if this brings back the display. Don't worry if you cannot see anything on the display by now, this process is done through the Fitbit app.
Let me know the outcome, I'll be around.
Best Answer07-09-2019 16:39
07-09-2019 16:39
I'm having the same issues, I currently up to four dead lines, I have tried resetting and changing the clock face, neither as worked at all
08-04-2019 01:47
08-04-2019 01:47
Hi,
I have the same problem with a charge 3 SE since yesterday. The given solutions (restart and/or changing the clock face) don't solve the issue.
11-27-2019 05:45
11-27-2019 05:45
I am having the same issue as well. There are a couple of dead pixels towards the top of my Fitbit Charge 3. I rebooted the device, and it has not helped.
11-27-2019 14:45
11-27-2019 14:45
I'm having this issue too... Yesterday it started with small lines and now have lots more... In few hours, the problem is getting worse 😩 I have restarted it, but sadly this doesn't solve the problem.
05-04-2020 22:00
05-04-2020 22:00
Same with mine. Now my screen is completely blank. Tried all resets with no luck.
05-04-2020 22:05
05-04-2020 22:05
Tried changing clock faces to. Outt went to having a few lines missing to having only a couple workin. Did resets, and changed clock face. Nothing worked and now now lines at all. It's still working as it vibrates Ann's still syncs with my phone just no display.
Best Answer05-28-2020 21:37
05-28-2020 21:37
Dear MarreFitBit,
I am having the same issues. 6 lines of dead pixels on my Charge 3 suddenly appeared this week. I have done the reboots that were advised in this forum, but no can do.
Also the battery life seems to have gone from 7-8 days to 4 days now. My usage pattern has remained the same since I bought the Charge 3 in January 2019.
Any ideas?
Best,
William
05-28-2020 21:48
05-28-2020 21:48
Best Answer05-28-2020 22:49
05-28-2020 22:49
Hello, there are black lines running through my charge 3 watch face and it no longer lights up when I flip my wrist. Please advise on how to fix this.
Best Answer05-29-2020 05:02
05-29-2020 05:02
It's no longer under warranty. I bought it in January 2019, and the warranty is 12 months 😞
