10-26-2023
08:10
12:05
ManuFitbit
10-26-2023
08:10
12:05
ManuFitbit
Charge 3 dim screen. Even when fully charged. Sometimes brighter but after a few seconds goes dim. Tried restarting.
Moderator edit: clarified subject.
10-26-2023 11:59
10-26-2023 11:59
It's good to see you participating in the community @Ros48.
I'm sorry to know the difficulty that you are experiencing with the device. Thank you for trying to fix it by your own.
I've been informed that you already contacted the Customer Support team for further assistance with this; in this case, they will let you know how to proceed. Please let them know of the steps that you already tried and keep an eye on your inbox.
10-26-2023 14:59
10-26-2023 14:59
10-28-2023 21:06
10-28-2023 21:06
I have the same issue and when I tried to get help was told to buy a new watch. Now the connected gps is running and the only way to turn it off seems to be on the device itself, which no longer lights up. My phone battery dies in a couple of hours since this started. Does anyone know how to turn off connected gps from the dashboard?
Best Answer11-03-2023 11:39
11-03-2023 11:39
Ich habe das gleiche Problem. Mein Display ist komplett schwarz, die Uhr vibriert aber. Neustart hat nichts gebracht
11-06-2023 23:35
11-06-2023 23:35
Is their an Antwerpen doe Thijs problem
Best Answer11-06-2023 23:36
11-06-2023 23:36
Is er een oplossing voor dit probleem
