Hi @Kjtoth Try restarting it several times and also try a long restart. If that doesnt improve it you will need to contact Suppprt.
CHARGE 3 LONG RESTART
Plug the device into the charging cable. While the device is plugged into the charging cable, hold the button down for 15 seconds. Remove your finger from button. Note: Device won't have a smiley face icon and should be off with a black screen. Remove the device from the charging cable. Plug the device into the charging cable again. The smiley face icon appears on the screen.
Helen | Western Australia
Best AnswerYes, I am sure it is annoying. Contact Support.
