01-25-2022
22:49
12:27
AndreaFitbit
01-25-2022
22:49
12:27
AndreaFitbit
I got given to me a Fitbit charge three from a friend now they disabled the screen because of the job they worked at on the app it says enter the number on your Fitbit charge three display but I can’t because it’s disabled
Moderator edit: Updated subject for clarity.
Can you ask your friend how they disabled the display? Maybe you could factory reset the Charge 3?
https://help.fitbit.com/articles/en_US/Help_article/2216.htm
CharlesKn | Mid-Atlantic, USA
60+, strength and cardio
Charge 5, Android, Windows
Not to be obvious, but when you connect to the charger, do you see the display do anything? If you connect to the charger and hold the side button down to reset, does the device vibrate?
https://help.fitbit.com/articles/en_US/Help_article/1186.htm
Best AnswerA user can not disable the display.
Holding in the button should do a restart and during the restart the display should show the fitbit icon.
My thought is that there is a problem with the tracker.
I'll also move this, non Charge 4 post, to Charge Board.
01-29-2022
12:32
04:24
01-29-2022
12:32
04:24
Welcome to the Fitbit Community, @BradyUschenko and thank you for your assistance @charleskn and @Rich_Laue. I´m sorry to hear your Charge 3 isn´t working.
As @Rich_Laue mentioned, Charge 3 display can´t be disabled. You can try setting up the tracker again but the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Keep on visiting the forums.
