02-02-2020
03:32
17:16
02-02-2020
03:32
17:16
After charging my Fitbit Charge 3 it has white lines across the screen. I had a previous Charge 3 which had the same problem and the company company replaced it, however I just called them explaining this is the same problem as the first one, and the best they can do is give me a 25 % discount. Probably will go with another brand before I purchase Fitbit again.
02-03-2020
04:13
08:08
02-03-2020
04:13
08:08
Welcome to the Community, @Guitarman249.
I understand how are you feeling. Our limited warranty provides repair or replacement of products that have a defect while still in the warranty period. Since your device is out of the warranty period, and therefore is not eligible for repair or replacement, our support team offered you a discount to thank you for your loyalty to Fitbit.
For more information about our warranty, you can click here. Also, you can check our comparison page, maybe there is a tracker that fit your needs and apply to the discount.
Let me know if you need anything else. 🙂
02-03-2020 05:10
02-03-2020 05:10
There must be some type of flaw in the charge 3 since I have had 2 of them and they both have had the same exact problem.
I also googled this problem and see that there are a lot of other people experiencing the same problem.
02-03-2020 06:56
02-03-2020 06:56
I have the same problem! The fact that my first charge 3 and replacement charge 3 didn’t even last a year is extremely disappointing. Has same problem with my charge 2. Seems to be a pattern Fitbit! The fact you won’t start new warranty with new replacement tracker says a lot!
