03-04-2019 07:30 - last edited on 11-17-2020 11:22 by MatthewFitbit
My Charge 3 display is so dim that I can’t read anything unless I’m in a dark room. I can’t see anything on the display while outside in the sunlight. I’ve tried the normal setting and the auto setting. And today my display is going completely blank. I reset it and changed the clock face. The display came back temporarily for 10 minutes then went blank again.
10-17-2019 15:42
10-17-2019 15:42
I need someone to reach out to me i need to get my fitbit fixed less than year old .
10-17-2019 17:35
10-17-2019 17:35
I using the app on iPhone 8. I talked with Fitbit support. Updated phone to iOS 13.1.2 and updated the app to the newest version (3.8) and it helped. Not great but better.
10-18-2019 02:44
10-18-2019 02:44
I am having the same problem, my display is so dark I cant read it most of the time!! How do I contact Fitbit please?
10-18-2019 05:25
10-18-2019 05:25
10-18-2019 07:21
10-18-2019 07:21
10-18-2019 09:04
10-18-2019 09:04
10-18-2019 09:05
10-18-2019 09:05
10-19-2019 13:46
10-19-2019 13:46
Having the same issue. It's gotten to the point that I can only see the tiny date on the bottom and nothing else. I contacted Fitbit and they didn't do anything for me. They just said it's a known issue and I just have to wait. No ETA was given and the customer service agent refused an exchange under warranty because they felt I'd end up with the same issue eventually with the second one. So I am stuck with a product that doesn't work.
10-19-2019 16:58
10-19-2019 16:58
11-02-2019 10:12
11-02-2019 10:12
yea fitbit wont fix or replace mine either. it's been 3 months of lip service. looking for alternatives to fitbit
11-02-2019 10:30
11-02-2019 10:30
11-02-2019 10:56
11-02-2019 10:56
11-02-2019 15:46
11-02-2019 15:46
congratulations, if they did that I would be happy. they are high priced devices and should have strive for customer satisfaction. curious how long ago this happened
11-02-2019 15:47 - edited 11-03-2019 13:16
hmmmm, strange
11-02-2019 15:52
11-02-2019 15:52
below is the 3rd email I received in as many months-
We appreciate your response and for your feedback on this matter.
We apologize for the inconvenience that this has caused you. Since you've already reported this issue on your Charge 3 to us, our engineers has been notified already and will work on finding a resolution as soon as possible.
At the moment, we ask for your patience and understanding.
Feel free to contact us again if you have any other questions.
Sincerely,
Angelito and the Fitbit Team
11-02-2019 16:13
11-02-2019 16:13
11-03-2019 13:12 - edited 11-03-2019 13:14
email I just received today from support
"We also get your point towards this matter however we the reason why we are not sending a replacement is because this issue is not yet resolved and will might happen again for the next replacement.
We also don't have a fix yet at this moment but rest assured that we are currently working to have it resolved.
Since your tracker is unpaired and unable to set up because the display, you will not be able to update the firmware to receive the fix."
So they wont repair or replace because it may happen again. I wonder why they continue to sell them if this is the case.
also since I made the mistake of trying to reinstall my fitbit(my bad) and cant pair it since I cannot see the pairing code I guess I wasted $150 on this charge 3.
lesson learned I guess
11-04-2019 13:20
11-04-2019 13:20
11-04-2019 13:40 - last edited on 02-14-2020 19:32 by LiliyaFitbit
I am having a similar issue, my device is not only dimmed but is fragmented, is like a tv with bad signal. I have follow all the step to reset the device multiple times, at first it was working but for the last couple weeks the issue remains regardless of the resets.
I would appreciate your help
Moderator edit: format
11-04-2019 14:20
11-04-2019 14:20
I wish I could help, all I can suggest is you talk to support and dont get a run around like I experienced. I feel for you!
