03-08-2019
20:39
11:22
03-08-2019
20:39
11:22
My screen suddenly turned white with vertical lines one night. Haven't dropped it or banged it hard or anything. It's getting difficult to swipe around the screen and it's just in general annoying. Plus my watch face won't activate when turning the watch towards my face like it used to.
Moderator edit: format and subject
03-08-2019 21:26
03-08-2019 21:26
Welcome to the forums!
Have you done a restart?
Keep us posted!
Wendy | CA | Moto G6 Android
03-10-2019 07:18
03-10-2019 07:18
03-10-2019 07:41 - edited 03-10-2019 07:41
I reset the tracker several times. To me it seems to be a hardware quality issue.
03-10-2019 07:52
03-10-2019 07:52
I'm having the same problem this morning. It was fine, I put it on to charge and when I came back I had vertical white lines across the screen. Have reset several times and nothing has changed.
03-11-2019 04:04
03-11-2019 04:04
Thanks for the update @Dstoke1 and @LucySue welcome to the Forums.
Since the restart process didn't work, I've gone ahead and escalated your cases to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
Keep me posted.
05-04-2019 05:03
05-04-2019 05:03
Hello. I am also having the issue where my charge 3 turned white with lines after plugging it in. Is this something that can be fixed on my end? If not, what steps do I need to take?
Thanks for your time,
Steve Blanda
05-04-2019 10:05
05-04-2019 10:05
I'm also facing the same issue. Tried restarting the watch but didn't help
05-14-2019 18:35
05-14-2019 18:35
My Charge 3 is doing the same thing. never bumped it or dropped it hard. I recently updated firmware and put on charger. Came back to white lines on screen.
05-14-2019 20:58
05-14-2019 20:58
I got a replacement tracker after a chat with Fitbit Support.
05-15-2019 01:08
05-15-2019 01:08
05-15-2019 04:23
05-15-2019 04:23
Hi.Can you tell me what was the procedure?Hoe did you got the replacement?please advice as I am having same issue and watch is still under warranty.marina
05-15-2019 07:12
05-15-2019 07:12
I was contacted by Fitbit support after I posted here which started up an email exchange where they asked me to try several things to attempt a reset - none of which worked in my case. They requested details of where and when purchased, determined it was still under warranty and opened up a replacement order which arrived in about 3 days after which I returned the original unit with the shipping label they provided. So far the new one is working perfectly.
05-15-2019 07:37
05-15-2019 07:37
You are very very lucky
07-01-2019 12:04
07-01-2019 12:04
I am having this exact same problem. My Charge 3 was bought in January 2019. Please let me know who to contact about this issue.
Thanks!
07-01-2019 13:44
07-01-2019 13:44
07-01-2019 14:48
07-01-2019 14:48
Hello!
I am having the SAME problem ... white vertical lines and it all seemed to have started with the last firmware update. Done all of the regular support suggestions ... multiple reboots, change the display clock face now several times... NOT Fixed! Please ... lover this watch, but need this resolved as it is now very difficult to swipe up or down or horizontally for the various menus or notifications.
07-01-2019 15:14
07-01-2019 15:14
12-11-2019 20:43
12-11-2019 20:43
Same issue. Contacted on-line chat support. Restarts and Resets unsuccessful. As out of warranty only (purchased late Oct 2018) only offered 25% discount. Charge 2 died within 2 years. Charge 3 now messed up at just under 14 months. Seems like a common systematic malfunction.
12-12-2019 05:09
12-12-2019 05:09
Same issue with mine and mine is only just out of warrenty as well.
