03-08-2019 20:39 - last edited on 11-17-2020 11:22 by MatthewFitbit
My screen suddenly turned white with vertical lines one night. Haven't dropped it or banged it hard or anything. It's getting difficult to swipe around the screen and it's just in general annoying. Plus my watch face won't activate when turning the watch towards my face like it used to.
Moderator edit: format and subject
04-05-2020 23:16
04-05-2020 23:16
Same thing just happened to mine -- White lines when I put it on the charger. Will it get even worse? It's just over a year old, so I suspect it's out of warranty. But I don't want to pay for another one so soon! This is my third FitBit.
04-08-2020 12:42
04-08-2020 12:42
04-17-2020 19:09
04-17-2020 19:09
I encountered this same problem today. The reset option did not work.
04-17-2020 21:01
04-17-2020 21:01
The same thing just happened to my charge 3. I removed it from the charger and white lines appeared on the display. I’ve tried restarting it and that didn’t resolve the issue
04-17-2020 21:10
04-17-2020 21:10
Mine has turned white too with lines through it. I’ve done several resets and it’s not helping. I’m not seeing how to fix this problem??
04-18-2020 01:43
04-18-2020 01:43
I don't think there is a fix for display turning white. I was lucky fitbit replaced mine free of charge as it was only just out of warrenty. I suggest you get in touch with them.
04-18-2020 02:20
04-18-2020 02:20
Mine started turning white yesterday evening. Initially it was just few lines now it’s all white. I have tried rebooting it but it’s still the same. It’s not as sensitive to touch anymore. I was wearing it so I know haven’t banged it or waters gone into it.
04-27-2020 19:29
04-27-2020 19:29
This happened to me this morning. I changed the clock face and turned it off then back on again. The face is still white with vertical lines. How can I make this go away??
04-28-2020 08:24
04-28-2020 08:24
07-20-2020 10:35
07-20-2020 10:35
This just happened to me. I just took it off the charger and my screen is white. I did a few resets and changed the clock face. It's still white. This is my 1st Fitbit. I got this Charge 3 when they 1st came out in October of 2018. I didn't expect it to last a lifetime, but I couldn't get 2 years out of it? From reading other posts, it sounds like this is a common problem. This might be my 1st and last Fitbit.
07-20-2020 10:54 - last edited on 08-09-2020 20:24 by LiliyaFitbit
I couldn’t get it fixed after troubleshooting and talking to support. It seems like there’s no coming back from that issue. They offered a discount on a replacement though
Kindly,
07-25-2020 07:00
07-25-2020 07:00
I had the same thing happen. I just don’t get it. Mine is getting worse by the minute. I can’t live without it!
08-09-2020 14:54
08-09-2020 14:54
Mine has just started to do this. I have not banged it around and am pretty careful with it and the screen is white with lines... Please, how do I fix this?
08-09-2020 20:01
08-09-2020 20:01
Hello
This has happened on 2 ~ Charge 3 watches! All those suggestions like doing resets that they outline did absolutely nothing to correct that issue in both watches. I don't think its anything you have done... the watches I think have an inherit problem with the displays and "I don't think these watches are shockproof either!" I do Martial Arts and Boxing.. my problem popped up immediately after doing my boxing! Seeing your post ... After 1.5 years has passed and this issue persists with their product.
The first time it happened, they replaced it under warranty. "Fitbit is very good about that" ... had me do a few troubleshooting steps .. eg Resets and then offered to replace it. Then the Warranty expired on the replacement unit ... it did the same thing! Note: they do NOT extend the warranty on any free replacement unit, that is what I was told. IF the unit is not under warranty, they did offer me a discount on a new one but at time it was no better than the prices I saw at the local favorite Best Buy!
Wish I had better news or suggestions to resolve the issue .. Good Luck!
09-18-2020 05:43
09-18-2020 05:43
I have the same issue. I followed the tips given, didn't work. Screen is the same. I bought my fitbit Jan. 2020.
09-18-2020 09:36
09-18-2020 09:36
09-20-2020 02:56
09-20-2020 02:56
11-16-2020 18:40
11-16-2020 18:40
Mine is doing the same thing. Rebooted several times but still white
01-27-2021 01:26
01-27-2021 01:26
Same here and this is not the first time! I think the device is pre-programmed to self combust after a certain period to force you into buying a new one! Very frustrated with this issue
01-27-2021 04:10
01-27-2021 04:10
My Charge3 had the same problem at 13 months - ie 1 month out of warranty.
There seems to be an inherent fault that such a fault occurs so frequently - NOT acceptable.
