09-24-2022
05:34
12:15
AndreaFitbit
09-24-2022
05:34
12:15
AndreaFitbit
My charge 3 doesn't keep the charge anymore. Is it the battery ? I don't want to buy a new one.
If your Fitbit won't charge properly, there are a number of things you can try to get it working again. Make sure the Fitbit's charging contacts are clean, dry, and seated properly in their charger. If possible, try to restart your Fitbit, or use a different charger.
Regards,
Will
Best Answerhaving the same issue... wont charge.. found another charger...wont charge.. cleaned contacts ... wont charge.. what else is recommended
13:09
08:08
09-29-2022
13:09
08:08
Welcome to the Fitbit Community, @Salexandre, @jewelz804, thank you for your assistance @willjoe. I'm sorry to hear that your Charge 3 battery is not lasting and thank you for mentioning the steps that you have followed in order to correct this.
@Salexandre, I noticed that you already got in touch with our team and received assistance.
@jewelz804, to maximize your Fitbit device's battery life, see the tips in Can I extend my Fitbit device's battery life? If your battery stopped charging, try the solutions of: Why isn't my Fitbit device's battery charging?
