03-14-2019
17:15
11:22
03-14-2019
17:15
11:22
It receives texts but doesn’t vibrate when they come in. How can I set this up?
08-20-2020 19:56
08-20-2020 19:56
I had the same problem, where the Charge 3 would receive texts, but would not vibrate. It would also not display the screen when flicking my wrist. My phone and app were configured properly.
The solution for me turned out to be the sleep settings on the Charge 3 itself (not the app). After turning off the sleep mode it works just fine.
For me the issue appeared immediately following a firmware update. Not sure if that played into it, but seems more than coincidence.
08-21-2020 15:33
08-21-2020 15:33
09-29-2020 03:45
09-29-2020 03:45
Hi
I cant find anywhere "In the Vibration Settings section, turn on the Always Vibrate option.
Whereabouts is this located?
Deb
10-04-2020 11:14
10-04-2020 11:14
I'm having this same issue and followed all of these steps but still no vibration. My fitbit is up to date 1.88.11, my app is up to date. iphone SE 2020 ios up to date 14.01. DND not turned on, bluetooth working other vibrations working, notifications all turned on. The notifications show when I look for them, but there is no vibration to notify me of their occurring.
Called fitbit and after running me through all the obvious steps, they said there was a compatibility issue with the recent 14 ios upgrade and they were working on it. That was a week ago.
10-04-2020 11:35
10-04-2020 11:35
I just realized that the last update to fitbit 28.20001.8.11 added a Do Not Disturb to the watch itself. I've been checking to assure DND on my PHONE was off. Apparently when the fitbit updated, it defaulted to having DND turned on. Perhaps it updated at night when my iphone was on DND? Anyway, I turned OFF DND on the watch itself and that brought the vibration back when receiving notifications. I hope I don't have to change that every day. Having DND set for a particular time each night on my phone is all I need to stop my Fitbit from vibrating while I'm trying to sleep.
10-04-2020 12:26
10-04-2020 12:26
01-16-2021 12:47
01-16-2021 12:47
I have the same issue. It used to work and now it doesn't. Any ideas yet?
01-16-2021 18:05
01-16-2021 18:05
I’ve found after every ios update, my text & call vibration alerts stop working. But between turning notifications on and off on my phone, and making sure DND is turned off on my fitbit charge 3 (hold down left side of fitbit until DND/Sleep/Screen Wake menu appears, press DND to turn off if on), it usually starts working again. Though, I can’t tell which image is “on” and “off” so I end up having to play with it for a few mins while having someone text me to test if the vibrations work again. Hope that helps!
01-17-2021 07:32
01-17-2021 07:32
