09-25-2021
13:07
11:29
CindyMFitbit
09-25-2021
13:07
11:29
CindyMFitbit
Hi
My screen is fading and impossible to see when outside. I’ve tried restarting it and charging it. I used to have the setting on screen display set to Auto but had to change it to normal because the auto would constantly make it too dim to see.
09-25-2021 13:15
09-25-2021 13:15
I am experiencing the same problem.
Best Answer09-25-2021 17:10
09-25-2021 17:10
Same problem with my charge 4
Best Answer09-26-2021 11:55
09-26-2021 11:55
Welcome to everyone! It's great to see you around.
Thank you for taking the time to report this issue. I appreciate your efforts and the additional details shared. If you haven't done so, I recommend making sure that the Sleep Mode option is disabled on your Fitbit Charge 3. When the sleep mode setting is on:
To turn off Sleep mode: Press and hold the button, and swipe left to access the quick settings screen. Tap Sleep to turn it on or off. When you turn off the setting, the icon appears dim with a line through it.
@mcilroy2001 You can review the same settings on the Charge 4 to see if that fixes the issue.
Hope this helps.
Best Answer09-27-2021 11:19
09-27-2021 11:19
I have the same with my Charge 3 but the display is faded to such minimum that I cannot see what I'm doing...
The tracker is 1 year old but I have the impression the display is broken, please advise what to do
Thanks,
Anja
Best Answer09-27-2021 11:32
09-27-2021 11:32
Welcome @Anja1000 It's nice to have you on board.
Thanks for the details shared on your post. If you already reviewed the settings as described above, I suggest performing a restart as listed here. If the issue persists, let's try to perform a long restart. A long restart is different than the basic one and you can complete it by following the instructions below:
Hope this helps.
Best Answer09-27-2021 19:10
09-27-2021 19:10
Hi!
I have tried all of the steps above and it is still faded and impossible to see outside. I’ve restarted it and made sure sleep mode was off.
Best Answer09-28-2021 09:30
09-28-2021 09:30
Thanks for responding @Rae9.
I'm sorry to hear that the inconvenience has persisted, my best recommendation is contact our Support Team so they can look deeper into the issue and help you with this matter. You can contact them through chat or over the phone. Click here to get connected. Make sure to mention the steps you've followed, so they can help you from there.
See you around.
