06-05-2020
14:12
10:31
AlejandraFitbit
06-05-2020
14:12
10:31
AlejandraFitbit
I find the display of time running impossible to read without glasses. When the stopwatch is on the most prominent display is distance covered. This seems like poor design. Is it possible to change the display?
It's great to see you around, @ReturnofChorb.
Regarding your inquiry, no, there isn't an option to change the font of the Charge 3. If you want to see your stats while running, you can tap the tracker's display to change the screen.
If this problem is directly with the font, we do not currently have plans to change this. You can learn more about how Fitbit decides what suggestions get released in our FAQs. For now, we will leave this suggestion open for votes (and closed to comments) so that we can continue to track community demand over time.
Let me know if you need anything else.
06:36
04:11
12-03-2020
06:36
04:11
Thanks for getting back, @ReturnofChorb.
Regarding your inquiry, yes, you can adjust the bitterness of your tracker by opening the Settings app directly from the tracker and swipe up to see the full list of settings. Tap the brightness setting to adjust it.
Keep me posted.
