02-08-2019
08:20
11:25
02-08-2019
08:20
11:25
Hello,
This morning, my Fitbit Charge 3 screen had gray lines going across it. It wasn't like this when I first got up the morning at 5:30am but appeared around 7am. It also doesn't seem to be reacting as well to my scrolling. It will still work but it seems slower and requires more pressure to scroll through the screens. Is there a problem with the screen? I have had this Fitbit for less than a month. I never have taken it into the shower or pool so the most water contact it has had is when I have washed my hands. I tried to reboot it and change the watchface but the gray lines are there. Any help would be much appearicated.
Thank you
02-08-2019 10:04
02-08-2019 10:04
@mrbees500, welcome to the community. Here're few things you may try for troubleshooting:
1. Restart Charge 3
2. Change clock face (you can change it back to your preferred one later)
3. Perform Long restart:
Please, let us know how it goes!
02-09-2019 10:36
02-09-2019 10:36
02-09-2019 10:38
02-09-2019 10:38
Thank you for the suggestions but they did not work 😞
Best Answer02-09-2019 10:50
02-09-2019 10:50
@mrbees500, that's too bad... please, contact Customer Service for further assistance.
10-02-2019 10:59
10-02-2019 10:59
I have tried all of the ideas on this forum and my fitbit charge 3 still has the grey screen. Now when I do the long reboot, the progress bar stops at near the end and nothing happens. I then disconnect it from the charging cable and it then brings up the smiling face and still has issues.
10-20-2019 01:52
10-20-2019 01:52
Hi. My charge 3 screen has got grey lines on it. I have read other posts regarding this and followed the instructions such as restarting it, changing clock face and holding down the but for 15 seconds but my screen is now grey all over. I’ve only had my charge 3 since May. Is there anything else I can try?
02-15-2020 21:33
02-15-2020 21:33
Hello,
I have the same issue with the black and gray screen on my Fitbit. I've tried all the steps to reboot & also restart my device several times but the problem still persists. My screen won't scroll and it's now a nightmare to use interval timer to workout.
I bought my device in October 2018 and support informed that my 'product does not meet the replacement requirement of the warranty policy'. This is very disappointing as it's been only over a year since I got my Fitbit and there seems to be no way to resolve this issue.
04-12-2020 07:14
04-12-2020 07:14
Mine did this Friday night when I put it on the charger. Mine has never been worn in the shower. I have tried the rest and placed it back on the charger and it is still showing this grayed screen with lines
Best Answer04-12-2020 07:25
04-12-2020 07:25
I have same gray lines issue, restarted changed clock faces nothing changed.
i can’t email support for replacement or questions?
Best Answer04-12-2020 07:29
04-12-2020 07:29
After doing all long restarts it now just shows black screen but it does sync with app, any other thoughts to get this going?
Best Answer04-12-2020 07:31
04-12-2020 07:31
Best Answer04-12-2020 07:58
04-12-2020 07:58
My screen now looks like this. How do I contact a customer support agent to get it replaced?
Best Answer04-12-2020 08:46
04-12-2020 08:46
I have tried these steps, I was unable to perform a long restart, and the lines are still visible.
Any additional support you can provide would be much appreciated.
Thanks!
Best Answer04-12-2020 12:38
04-12-2020 12:38
thats how mine looks now also...... I sent a message through facebook could not find any other way to reach them no way to get reach a contact option through the fitbit page always brings you back to the same support - community pages its like they don't want to communicate and help with issues.
Best Answer04-12-2020 12:54
04-12-2020 12:54
Hi.
Try contacting them through here:
https://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
I found them very helpful as my Fitbit was still in warranty. Hope you get it sorted.
Best Answer04-12-2020 13:42
04-12-2020 13:42
04-19-2020 21:52
04-19-2020 21:52
That is exactly how mine looks now. Just happened today.
Best Answer04-19-2020 22:56
04-19-2020 22:56
Hi.
you need to click email us , fill in what Fitbit you have etc. Type a brief message of your problem. They get back to you in a few days. I found them to be very helpful. Hope this helps.
Best Answer04-24-2020 01:13
04-24-2020 01:13
I have the same problem with my fibit Charge 3
make a shutdown with 15s
restart with 8s
restart from menu
and at last erase all user data
just nothing happens
what can i do
