01-23-2020
07:48
17:35
01-23-2020
07:48
17:35
I have been sitting in meeting for 5 hours today, and Fitbit says I have been active for 405 minutes, with 5,800 calories burnet. i wish!! Heartrate is also going totally crazy, between 140-150 all day. At the same time, the battery lasts for only half a day. Anyone else experiencing the same? What can be done to fix this?
01-24-2020 05:41 - edited 03-27-2024 13:18
Hello there @Krilis, thanks for stopping by and for the details provided.
I'd recommend restarting your Charge 3 by following the steps in the article: How do I restart my Fitbit device?. After performing the restart, please keep an eye on your tracker's behavior. Also, I'd like you to check the information provided in the article: How accurate are Fitbit devices?
In regards to the battery not lasting, I was wondering where you charge your tracker? Have you checked if by any chance the USB port or outlet is faulty? If you haven't done so, try a different port. A UL-certified wall charger will also work. Don't use a USB hub. You can find more detailed information in the help article: Why isn't my Fitbit device's battery charging?
Also, I'd like you to review the tips and recommendations provided in the article: Can I extend my Fitbit device's battery life?
As a friendly reminder, the following are some factors that have an impact on battery life and may cause your battery to drain more quickly:
If you still believe your battery is not lasting as long as expected, we’d like you to do a battery test to see how long your battery lasts after a full charge. Please do the following:
Best Answer01-24-2020 05:46
01-24-2020 05:46
Hi!
Thanks for your reply. I will restart my Charge 3 and do the battery test. Will report the results!
Best regards,
Krilis
01-24-2020 06:01 - edited 03-27-2024 13:18
Great! I'll be looking for your results @Krilis. 😉
Have a nice day!
Best Answer01-27-2020 00:13
01-27-2020 00:13
Hi!
I followed your tips with restart and syncing during the weekend. From Friday evening, the battery lasted for 18 hours, with only 2 syncs during the day, and no notifications or GPS-activity interruptions. Actually I have never used notifications on my tracker, so it can't be this that drains the battery.
I restarted the tracker once more yesterday. It was fully loaded at 1 PM, and now 20 hours later, the battery is 84%. Not that bad. Hopefully the battery now will last for days!
Best Answer01-27-2020 14:28 - edited 02-23-2024 03:43
Thanks for getting back @Krilis.
Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Let me know if there's anything else I may do to help you.
