11-06-2020
07:54
12:57
11-06-2020
07:54
12:57
My charge 3 screen consistently turns on and off with out me looking at it and it wears the battery down. I have turned off notifications and reset the charge 3. Not too sure what else to try.
Hi there @Corie1, welcome to the Community Forums. I'm sorry to hear about your Charge 3's recent behavior, I understand where your concern is coming from. Thanks for already troubleshooting your tracker, I'll be glad to continue to help you.
I'd recommend trying a long restart on your Charge 3 by following the steps below:
Let me know how it goes.
Hey @Corie1, sure thing. Keep me posted on the outcome. 😉
Best AnswerHi,
I tried restarting the charge 3 as you suggested and it is still blinking off and on. Is there anything else you may suggest. Thank you again
Hi there @Corie1, thanks for the update.
I appreciate you had followed the tips and recommendations provided above. Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual.
We hope your issue is solved soon.
Best AnswerHi,
I tried to plug in and restart and it keeps blinking. It worked for a day and is now back to blinking. Is there anything else I can try?
thank you
