01-29-2021
22:16
03:10
01-29-2021
22:16
03:10
Hi ,
My fitbit charge 3 is dead . I tried all the solutions provided in the forum but it has not worked. I bought this product in Dec 2019 , not even 14 months and now it's dead completely. Please help what should be done. Can I get it repaired or exchanged. I am based out of Sydney.
02-04-2021 02:53 - edited 09-15-2023 10:24
Hi there @dyehl1, welcome to the Community Forums.
If you're experiencing the same issue with your Charge 3, please be advised to follow the the steps I recommended here.
As for the Charge 2, please note when a tracker suffers damage while under warranty, you can contact Customer Support. Discounts and replacements depend on tracker model and other factors.
However, as our warranty states, it doesn't apply to damage or defects caused by:
(a) use with non-Fitbit products
(b) accident, abuse, misuse, mishandling, flood, fire, earthquake or other external causes
(c) normal wear and tear or aging of the Product such as discoloration or stretching
(d) operating the Product:
(i) outside the permitted or intended uses described by Fitbit
(ii) not in accordance with instructions provided by Fitbit
(iii) with improper voltage or power supply.
For more information about this, you can check our warranty policy.
Best Answer01-30-2021 03:14
01-30-2021 03:14
Hi there @PankajSonawane, welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Charge 3 before reaching out. I understand how you must be feeling.
To better assist you, would you mind giving me more details of the issue with your Charge 3? Is it not syncing, charging, pairing? Along with that, let me know the steps you've done to solve that issue.
Looking forward to your response.
Best Answer01-30-2021 03:43
01-30-2021 03:43
Best Answer01-30-2021 03:47
01-30-2021 03:47
@PankajSonawane Thanks for the details. If your Charge 3 is not vibrating either for the restart or when you try to charge it, please try the steps below:
Let me know how it goes.
18:20
05:08
01-30-2021
18:20
05:08
Hi ,
I did cleaned with alcohol and put on charging again. Now it's vibrating
but not showing up anything on screen. For a moment there were few dead
pixels but then it's all blank.
Yes ...true , this doesn't instill confidence to buy a new one even if I
get a discount. Fitbit should work on the bands long life.
Moderator Edit: Merged posts
Best Answer02-01-2021 05:07
02-01-2021 05:07
@PankajSonawane I appreciate you had followed the tips and recommendations provided above. I understand where you're coming from.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
Best Answer02-03-2021 18:31
02-03-2021 18:31
This is the same thing that has happened with my charge 3. I put it on charge and then take it off and 5 seconds later it says the battery is 1 %. I just got this watch about 1 month ago. Now, I using my fitbit charge 2 watch that I've had for 2 years. The screen has a few cracks so I got another one. Big mistake.
Best Answer02-04-2021 02:53 - edited 09-15-2023 10:24
