05-09-2024
11:05
07:34
05-09-2024
11:05
07:34
How do I fix the time on my watch? It’s always running slow about 2 minutes but now it’s 5 minutes slow
Hi there, @Linphoto. Thanks for stopping by in the Fitbit Community Forums and for the details provided in your post. I will do my best to help you with this!
Did you already sync your Fitbit device? Please keep in mind that your Fitbit device may show an incorrect time if it hasn't synced or has been unpaired from your Fitbit account. Your Fitbit device uses the time of the device you're syncing with. Since you've recently recharge it, maybe your Charge 3 just needs to sync to update the time.
If you've tried the above but to no avail, make sure you're not running into syncing issues. For more information, see Why won't my Fitbit device sync?
If the issue is still not solved, but you can confirm that your Charge 3 is syncing, I recommend changing your time zone to a completely different one, sync your device, put the correct time and sync again.
