10-07-2021 09:10
10-07-2021 09:10
Ever since I updated Fitbit this month, I’ve had nothing but issues with syncing & constantly disconnecting from Bluetooth. I have removed the device off the app & on my phone. Majority time when I add the Fitbit it’s stuck on connecting & won’t pair. I’m constantly doing this 10-15 times & when I it does pairs, it will drop again & no longer sync after 5-10 mins. I’m so frustrated & I’ve been trying everyday for almost a week, I’m at the point where I’m leaning towards getting an Apple Watch
10-07-2021 11:01
10-07-2021 11:01
Welcome to the Community Forums @Lolat13.
Thanks for the details shared on your post, as well for your efforts while working on this matter. Because you mentioned it disconnects from Bluetooth, do you receive an error message when trying to sync? Is the Fitbit app updated? In the meantime, please try the following to reconnect your tracker to your account:
Hope this helps.
Best Answer10-07-2021 11:56
10-07-2021 11:56
I have done all this numerous times. This all started when I updated Fitbit app this month
Best Answer10-07-2021 13:01
10-07-2021 13:01
Thanks for your response @Lolat13.
Thanks for letting me know that you already tried all of this. Let's double check some additional tips, listed here. If the issue persists, my best recommendation is contact our Support Team so they can look deeper into the issue and help you with this matter. You can contact them through chat or over the phone. Click here to get connected. Make sure to mention the steps you've followed, so they can help you from there.
See you around.
