03-08-2019
04:56
11:22
03-08-2019
04:56
11:22
03-08-2019 13:36
03-08-2019 13:36
Welcome on boad @Rocky101, it's nice to have a new member around! If your Charge 3 won't stop vibrating, I'd recommend restarting it by following these steps:
Hope this helps, let me know the outcome!
03-08-2019 13:36
03-08-2019 13:36
06-30-2019 13:58
06-30-2019 13:58
It worked a treat
thanks for your support
Best Answer07-02-2019 11:35
07-02-2019 11:35
Welcome on board @Johnd1950! I'm very glad to hear that the steps suggested above solved the issue you were having with your Charge 3.
I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
Best Answer04-13-2020 23:42
04-13-2020 23:42
When I followed these directions a flat line appeared on my screen. I took it out of the charger and it displayed the happy face but it kept buzzing and flashing between the screen wake/Notifications screen and the clock which is the wrong date & time. It’s like it has a short in it or something.
06-23-2020 08:43
06-23-2020 08:43
I did this. First, it does nothing. It's fully charged. It just keeps vibrating displaying the different screens.. Cannot get it to stay on any screen long enough to clear the data or reset it.
Any other suggestions?
07-20-2020 08:35
07-20-2020 08:35
I did this. The white eine appearded and the happy face at the end, but it is still vibrating and my display is active all the time. Like I was touching it.
Can you please help?
Best Answer07-20-2020 15:55
07-20-2020 15:55
I followed the instructions everyone gave. Trying the new clock face. I got on the tech board. I did the long reset. That seemed to work for about 10 hours and then it started vibrating again. I got on the chat with FitBit Tech Support they confirmed that I did the long reset and that it didn't work. They had me try again, it didn't work.
They said good news, we are going to send you a brand-new FitBit. And about a week later my brand-new FitBit showed up.
They said if it doesn't respond to the long reset after two times you need a new one. mine was still covered under the original manufacturer warranty. Square Trade would have covered it. But it was still under warranty. I did some more research and found that this happens if you do not take it off before you shower or take off and dry it when you're done. They also don't recommend swimming with it although swimming is one of the activities it tracks. If you do decide to swim with it. They say take it off right away and dry it. Take off both ends of the band and dry it. what a pain in the neck.
Best Answer09-12-2020 14:49
09-12-2020 14:49
my fitbit charger 3 doesn't have any buttons so how can I reset it to stop the vibrating
Best Answer10-25-2020 15:59
10-25-2020 15:59
Didn't work, but thanks
Best Answer01-22-2021 00:47
01-22-2021 00:47
Hi,
I’ve tried the suggestion but it hasn’t worked!
Best Answer01-24-2021 05:53
01-24-2021 05:53
Best Answer02-14-2021 08:19
02-14-2021 08:19
i started experiencing this today, a few minutes ago. I'll check if it is the cable, as I have my husband's cable handy... (the reset did not fix the problem) and I do not know how to do the hard reset
08:57
11:14
AndreaFitbit
02-14-2021
08:57
11:14
AndreaFitbit
the cable did not fix the problem. it seems that it is working but it vibrates randomly
I also did a hard reset by going into settings and doing a reboot. It stopped vibrating for about 40 mins and now it started again.
Moderator edit: updated post.
Best Answer02-15-2021 17:18
02-15-2021 17:18
17:47
06:05
AlvaroFitbit
02-15-2021
17:47
06:05
AlvaroFitbit
no! I'll try that tonight. it now seems totally dead, but when it wakes, it
vibrates and runs through screens and then dims...
Moderator Edit: Personal info removed
Best Answer03-21-2021 07:19
03-21-2021 07:19
My charge 3 started doing this after I pulled it off the charger yesterday. Acting like something was touching the screen constantly but nothing was. I tried the 8 second restart as well as a 15 second restart multiple times and now all it will do is sit and vibrate. My phone can no longer see it to sync or update. It occasionally will 15 second restart on it's own when on the charger.
Best Answer03-21-2021 12:02
03-21-2021 12:02
Best Answer12-17-2021 20:02
12-17-2021 20:02
Hey all. By chance, when your Fitbit charge 3 was vibrating , did the green light on the back stay on? Was there a feint green circle appear on the screen - looked like a tiny green exploding firework (best way to describe it)? Mine started vibrating on my wrist after I charged it. then the above happened. The green light kept flashing all night until my Fitbit lost charge the following day - because it ran the battery down (had been fully charged)
Best Answer02-16-2022 07:23
02-16-2022 07:23
Same problem here. But i contacted fitbit suuport last night and they say to me that they cannot fix problem coz my charge 3 was allready replaced what is thrue. But fitbit company sed me refrubished charge 3 wich has a problem. So im so disapointed with fitbit service. Product are low quality ok but you guys need something to give to custimer or quality or service.
