09-23-2019
02:01
10:43
09-23-2019
02:01
10:43
Does anyone have any advice to troubleshoot screen issues on a charge 3? The screen has a single horizontal line at the top and multiple fuzzy verticals lines. It is less than 1 yea old. I have performed a reset but it made no difference.
09-24-2019 05:58
09-24-2019 05:58
Hi @Zanbranford, welcome to the Community Forums. Thank you so much for restarting your Charge 3 prior to contacting us. Nice way to go!
I've created a support case on your behalf - you should soon receive an email from Customer Support at the email you used to register with the Community forums. If you have any questions, don't hesitate to let me know. 😉
Best Answer09-24-2019 06:29
09-24-2019 06:29
My charge 3 is doing the same thing and tried restarting a few times. It was low battery last night and I charged it and there’s lines stuck on the screen now.
Best Answer09-26-2019 12:36
09-26-2019 12:36
Hello there @Tiffanyz2, welcome on board. Thanks for already restarting your Charge 3.
I was about to create a support case on your behalf, but I've seen you contacted our Support Team after posting here and that they have helped you with this. Please keep an eye on your inbox for updates on your case.
Let me know if there's anything else I may do to assist you with.
Best Answer09-26-2019 12:42
09-26-2019 12:42
I am also having the same issue. Restarting my Fitbit did not help.
Anything else I can try?
Any help would be appreciated.
Mandy
Best Answer09-26-2019 12:47
09-26-2019 12:47
I just received a replacement charge 3 maybe a month and a half ago. Now this one gave lines in the middle of the screen. Is there a defect on these fitbits? Is the replacements refurbished or brand new?
Best Answer09-27-2019 10:00
09-27-2019 10:00
Hi @MJR1964, welcome on board. Thanks for already restarting your Charge 3.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon! 😉
Hello @Nakeil, welcome to the Community Forums. I'm sorry to hear your Charge 3 replacement has developed lines on the screen.
Please restart your device by following the steps below:
In regards to your question, depending on available inventory, we sometimes issue factory-certified refurbished products as warranty replacements. These are typically products that were returned to Fitbit unused for reasons like wrong size and wrong color. This product is tested and determined to work like new, with minimal wear and tear.
Let me know the outcome, I'll be around.
Best Answer10-01-2019 15:32
10-01-2019 15:32
Best Answer10-01-2019 17:09
10-01-2019 17:09
Mine has vertical and horizontal lines and even worse it won't swipe to other screens and earlier when I would pause a workout it would randomly start back up. Less than a year old
Best Answer10-01-2019 23:10
10-01-2019 23:10
Best Answer10-03-2019 12:39 - edited 04-05-2024 05:47
Hi there @Nakeil, thanks for letting me know the outcome of the steps I recommended. I went ahead and created a case for you with our Support Team. Someone will reach out to you soon to offer their assistance. Please keep a lookout in your inbox to the email address associated with this account.
Hello @jreedorchard. I was about to create a support case on your behalf, but I've seen you contacted our Support Team after posting here and that they have helped you with this. Please keep an eye on your inbox for updates on your case.
Hey there @Zanbranford. I'm seeing that our Support Team has been helping you since you posted here. Keep an eye on your inbox.
I'll be around if there's anything else I may do to assist you in the meantime.
Best Answer10-03-2019 14:23
10-03-2019 14:23
Best Answer04-23-2020 10:36
04-23-2020 10:36
I am also having a problem with fuzzy vertical lines on my charge 3. I have rebooted the device with no improvement. Also having problems with swiping to see the apps on the tracker.
Best Answer04-23-2020 10:49
04-23-2020 10:49
Best Answer04-23-2020 13:01
04-23-2020 13:01
Yes this actually happened twice and Fitbit replaced it.
Best Answer04-23-2020 14:06
04-23-2020 14:06
Mine is showing the same problem after I charged it, I tried reset and changing the clock face. Any ideas? I have only had it for a couple of weeks
Best Answer09-18-2020 05:09
09-18-2020 05:09
Hi, I have a charge 3 and never had an issue. Just literally put mine on charge and I now have the lines everyone mentions. Tried restarting and no joy. Please let me know the next step
