11-18-2021
03:14
15:39
EdsonFitbit
11-18-2021
03:14
15:39
EdsonFitbit
This is the 4th replacement charge 3 that I have had all the previous ones had the same problem. First it starts to loose time, then it won't sync. You try all the reloading etc that you're told to do but it doesn't work. So not even bothering with this one.
Is this a charge 3 problem.
11-29-2021 15:38 - edited 11-29-2021 15:43
Thank you for visiting the Fitbit Community, @Pangym.
I'm sorry to hear about the difficulties you experienced with your Fitbit Charge 3. Thank you for trying to get them resolved before contacting us.
To resolve syncing issues, we recommend following these troubleshooting steps.
In addition, you can set up your Tracker as a replacement device:
Your Tracker should show the same time on your phone, however if after syncing it still shows the wrong time you can follow these steps to fix it.
If you have followed the instructions shared above without luck, the best way to get help for this problem is to chat with us online or give us a call. Please click here to get connected.
Have a nice day.
