10-23-2022
17:36
09:03
10-23-2022
17:36
09:03
Hi there, @Jetstream. Welcome to the Community Forums. Thanks for reporting this issue with your Charge 3.
Have you tried following the troubleshooting steps provided in this help article? If so, please make sure your phone meets the requirements listed here.
May I know if the Sleep Mode and DND settings are turned off? If these settings are on, your tracker won't vibrate or turn on when receiving any type of notifications. You'll find more details about these settings here. Also, make sure the Show Previews is set to Always or When Unlocked for your preferred apps under your phone's settings > Notifications.
If the issue persists after double checking the above settings, give a try to the following:
Hope this helps.
Best AnswerMake sure your phone is within 30 feet of your Fitbit. Check that you turned on Bluetooth on your phone and that your phone has notifications on. Verify that you turned on notifications in your phone settings and within the Fitbit app. Turn off Do Not Disturb and Sleep Mode (if available) on your phone and Fitbit.
Regards,
Will
11-02-2022
19:46
09:02
11-02-2022
19:46
09:02
@willjoe Thank you for adding those tips!
Have a great day.
