01-04-2021
20:29
03:08
AlvaroFitbit
01-04-2021
20:29
03:08
AlvaroFitbit
Hi...
I have my CHARGE 3.
It automatically got unpair. And now I am unable to Pair It.
The unit is purchased in US on Site & using in India. ( It was purchased in Feb -20. )
I have follwoed all the Steps as mentioned in so many chats & on community.
Noting is working.
Need your help.
Moderator Edit: Personal info removed
01-05-2021
03:09
04:35
01-05-2021
03:09
04:35
@Nitinmaitra24 I hope you're doing well!
Let me help you with this and thank you for troubleshooting this issue. You don't mention which steps you have tried so I suggest you clear the link between your phone and your tracker by doing the following:
Let me know how it goes.
Best Answer01-05-2021 05:50 - last edited on 02-10-2021 19:07 by LiliyaFitbit
Dear Alvaro,
I have tried all the suggession mentioned on Fitbit Community. Which included Restart of Fitbit / Cellphone. Bluetooth OFF / ON.
Uninstall of FITBIT & Re-Install of FITBIT.
I have tried it to install on Google - Pixel Cell as well. But not worked. It didn't paired.
Noting is worked out.
No physical damage to CHARGE 3, but just now I am noticing some lines in clock are not working.
Infact both side of belt broken & for which I got replacement.
I need your immidiate attention.
Pls suggest / resolve.
Thanks in anticipation.
Regards,
10:06
04:35
01-07-2021
10:06
04:35
@Nitinmaitra24 thank you for the update.
I noticed that you already have a ticket with our Support team so please work with them to find a solution. Also please note that due to recent events affecting our operations, Support may need more than 7 business days to respond.
Best Answer01-13-2021 19:45
01-13-2021 19:45
Dear @ Fitbit - Request you to help.
Pls provide the solution to outcome.
Regards,
Nitin
10:37
04:34
01-14-2021
10:37
04:34
@Nitinmaitra24 thank you for your reply.
Since you haven't been assisted I have created a new ticket. Support will contact you via email.
Keep me posted.
01-16-2021 07:17
01-16-2021 07:17
Dear Alvaro - I have recd mail.
I have tried the procedure mentioned. But it did not worked.
Pls suggest solution.
Regards,
Nitin
11:48
04:34
01-18-2021
11:48
04:34
Thank you for the update @Nitinmaitra24 .
Please keep communicating with Support via email and let them know that the troubleshooting steps didn't work for you.
I'll be around.
Best Answer01-22-2021 01:45 - last edited on 02-10-2021 19:07 by LiliyaFitbit
Dear Alvaro - Pls help.
It is still not working.
The unit is purchased in US & using in India. ( Feb 20 . )
If No solution... pls help me with Warranty Replacement. I am not able to generate in FITBIT App.
Regards,
Best Answer01-26-2021 02:34 - last edited on 02-10-2021 19:07 by LiliyaFitbit
Dear Alvaro,
Good to inform you that that the Charge 3 got paired.
Today I have uninstalll the App from my Cell. Restarted the cell & Charge 3. Followed the Steps.
Thanks.
Now ONLY ONE PROBLEM remained.
No physical damage to CHARGE 3, but just now I am noticing some lines in clock are not working. ( Which I mentioned on 5'th Jan 2021. )
Pls suggest how to proceed & if so, what I need to do from my end.
Pls take it on priority.
Regards,
11:25
04:34
01-27-2021
11:25
04:34
Only our Support team can look into your tracker's warranty and see if they can replace it so I suggest you contact them. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
I'll be around.
Best Answer02-08-2021 22:59
02-08-2021 22:59
Dear Alvaro,
My Charge 3 is working fine now.
As mentioned in earlier message 26 Jan & your reply Dt. 28 Jan, I have logged the Case # 39489572 Dt. 28 Jan.
No reply received yet.
As mentioned earlier, the unit is purchased in US & using in India. ( Feb 20 . )
Pls help.
Regards,
Nitin
09:43
04:34
02-09-2021
09:43
04:34
Hi @Nitinmaitra24 .
Sorry to hear that you haven't received a reply. I do suggest you try our Chat option that will be faster if it is available for you. Click this link to see your options.
Hope this helps.
Best Answer02-09-2021 16:51
02-09-2021 16:51
