10-12-2020
14:20
10:13
10-12-2020
14:20
10:13
The screen is light grey with horizontal lines and the battery dies quicker than usual. Restarted it several times and recharged the battery fully, even tried to change clock faces. No change.
Hi @Kalzig2not, welcome to our Fitbit Community. I'd like to follow up and help you with your Charge 3 since it's experiencing screen and battery draining issues. By the way, thank you for trying to get this issue resolved before contacting our forums.
I'd like you to try a long restart. To do so on your device, follow the steps below:
Regarding the battery draining issue, try the tips that are listed in this help article in order to improve the battery life of your tracker.
Finally, monitor your tracker's screen and battery behavior and see if the issues get fixed.
Keep me posted on the outcome.
