12-31-2018
06:48
14:31
12-31-2018
06:48
14:31
My Charge 3 just keeps flickering between the "Screen Wake" settings screen and the "Home Screen (Clock)" while vibrating as it goes back and fourth. I tried rebooting it while connected to the charger but it gives me the horizontal status bar as it reboots the freezes. The is no 🙂 ever given. I've had multiple issues with this Charge 3 since I purchased it around Thanksgiving. I've tried uninstalling the app and reinstalling as well as reconnecting but I'm at a point now where I can't do much as the device is just cycling through screens and vibrating uncontrollably. Also tried wiping it down to make sure there wasn't a fingerprint or something on the screen or sensor. No luck there. Ideas on if its defective and what I can do to resolve?
Charge 3
Firmware version: 28.20001.49.45
10-15-2019 03:47
10-15-2019 03:47
Just contact fitbit help desk with the issue.
They are very helpful and more likely than not will send you a replacement once they know you've tried all the recommended 'fix' steps.
They'll talk you through it.
10-18-2019 04:37
10-18-2019 04:37
Hi i am having the exact same problem with my charge 3 that I bought only 8 months ago.
10-18-2019 05:32
10-18-2019 05:32
11-03-2019 09:12
11-03-2019 09:12
I am having exactly the same problem. My charge 3 was a Christmas gift. It has now stopped working completely.
11-03-2019 12:02
11-03-2019 12:02
11-03-2019 13:02
11-03-2019 13:02
11-03-2019 13:34
11-03-2019 13:34
11-24-2019 19:59
11-24-2019 19:59
I got my Charge 3 last year for Christmas and loved it until last Friday when I was at the gym and it kept vibrating and flickering screens. I have tried to reset it several times as other post suggest, however it doesn't work. When it does flick to the home page it doesn't even have the correct time? It hasn't even been a year and I feel naked without it! Any help would be much appreciated!!
11-24-2019 21:39
11-24-2019 21:39
11-24-2019 22:00
11-24-2019 22:00
03-09-2020 05:35
03-09-2020 05:35
This just started happening to me and it will not stop flickering even when plugged in. I’ve had this tracker for over a year now and am very surprised that this just started happening. Any help would be great
03-10-2020 00:32
03-10-2020 00:32
Contact fitbit customer services directly, they are very helpful... They will ask you to follow certain steps, and if it doesn't fix it, (mine didn't) they will send you out a replacement fitbit.
04-06-2020 16:29
04-06-2020 16:29
I’m currently experiencing the same thing. It won’t stop from switching back and forth. It’s vibrating and my home screen has lines through it.
04-08-2020 23:20
04-08-2020 23:20
04-15-2020 21:43
04-15-2020 21:43
My fit bit charge 3 is doing the same thing, flickering nonstop between screens and vibrating uncontrollably. I can't get it to stop no matter what I try. What did you end up doing to fix yours?
04-16-2020 06:14
04-16-2020 06:14
04-16-2020 15:39
04-16-2020 15:39
04-28-2020 21:52
04-28-2020 21:52
I'm having the exact same problem and have not been able to contact tech support. My Fitbit is unusable.
04-28-2020 22:26
04-28-2020 22:26
04-29-2020 07:53
04-29-2020 07:53
