11-16-2020
00:05
10:13
11-16-2020
00:05
10:13
Charge 3 is also recording very high heart rate for no reason.
11-16-2020
03:11
07:12
11-16-2020
03:11
07:12
@Catherinerose30 I hope you're doing well!
Let me help you with your Charge 3 not working as it should. I suggest you clean the back of your device with cotton and rubbing alcohol and restart it (to help with the screen issues). Turn the heart rate off, save and sync then turn it on save and sync again. Also check these tips to improve the heart rate reading on your device.
Regarding the battery life try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. You can follow these instructions to help improve the battery life.
Let me know how it goes.
Best Answer11-16-2020 11:39
11-16-2020 11:39
Hi,
Thanks for your reply.
I’ve cleaned it, recharged it and rebooted it.
it’s still flashing, very strange!
What do I do now?
09:24
07:12
11-18-2020
09:24
07:12
@Catherinerose30 thank you for the update.
Since the issue persists I have created a ticket so our Support team can further assist you via email.
