09-14-2021
05:12
14:34
CindyMFitbit
09-14-2021
05:12
14:34
CindyMFitbit
My fitbit charge three also has missing lines. It started out with just a corner in the top left, but now its so bad that I can barely see any information on the screen at all. I've reset it and changed the Viv face and the lines remain the same. Please help! I love my fitbit and use it for work, but it's almost unusable now.
Moderator Edit: Clarified subject and label
@Tree2182 Welcome to the community forums!
Thank you for the information and for the troubleshooting steps you've followed prior to posting. I understand your concern.
If restarting your Charge 3 hasn't helped, you can also try to perform a long restart by following the steps below:
On a side note, I've moved your post to this thread so we can keep our forums organized.
Hope this helps.
15:06
11:27
09-16-2021
15:06
11:27
@Tree2182 Thanks for your reply and for trying the instructions provided.
As the inconvenience has persisted, my best recommendation is contact our Support Team so they can look deeper into the issue and help you with this matter. You can contact them through chat or over the phone. Click here to get connected. Make sure to mention the steps you've followed, so they can help you from there.
See you around.
