01-30-2020
05:36
17:16
01-30-2020
05:36
17:16
About 2 weeks ago I noticed that have of my Fitbits screen was so di. I couldn't see it unless I was in a dark room, a few days later the whole screen was dim. It is very inconvenient because now I can't use it to check time or exercise. I have tried resetting it multiple times, nothing has helped. Any help is greatly appreciated.
01-30-2020 16:54
01-30-2020 08:00
01-30-2020 08:00
Try a Long Restart:
CHARGE 3 LONG RESTART
Connect the device to the charging cable.
While the device is plugged into the charging cable, press and hold the button down for 15 seconds.
The device turns on and shows a battery icon. Two vibrations occur: first a short vibration, then a medium vibration.
The device turns off.
The device turns on and shows a progress bar and short vibrations occur. The progress bar completes. Note: A total of 7 short vibrations occur.
Remove the device from the charging cable. The device shuts down.
Important: Plug the device into the charging cable again.
Best Answer01-30-2020 16:31
01-30-2020 16:31
I tried restarting it multiple times but it is still extremely dim.
01-30-2020 16:54
01-30-2020 16:54
Contact Customer Support.
Best Answer01-31-2020 05:04 - edited 02-23-2024 03:45
Hi there @Mcooroipaehr, welcome to the Community Forums. Thanks for taking the time to troubleshoot your Charge 3's screen prior to contacting us.
I was about to create a support case on your behalf, but I've seen you contacted our Support Team after posting here. Please keep an eye on your inbox, someone will be in touch with you shortly.
Thanks for your help @SunsetRunner.
I'll be around if there's anything else I may do to help you in the meantime.
