10-12-2020
17:32
05:02
JuanJoFitbit
10-12-2020
17:32
05:02
JuanJoFitbit
Since Update last Month the brightest the watch gets is Dim and dim is almost a black screen I have reset watch and no change. I triple checked if it was me or not, but it is definitely the watch. I am not replacing watch as I feel that there nothing else wrong and I have only had this version for a year. Too many people seem to have same issue so it probably has to do with the last update. Please review data and changes and fix this issue.
10-13-2020 05:01
10-13-2020 05:01
Hi @Ksegobrown2, welcome to our Fitbit Community. I'm sorry to hear that the screen of your Charge 3 is dim, almost black. I totally understand how you feel about this and I appreciate the time spent trying to get this issue resolved before contacting our forums.
I'd like you to try a long restart. To do so on your device, follow the steps below:
Keep me posted on the outcome.
Best Answer10-13-2020 18:16
10-13-2020 18:16
I haven the same issue. Ever since the update I cannot read my watch outdoors. I have tried changing the brightness setting, changed clock faces to a different Fitbit clock, and restarting the watch. Nothing has helped.
Best Answer10-14-2020 05:40
10-14-2020 05:40
I did above no change... I'm not a tech, but from all the people reporting same issue and timeline with the last update. My guess is this is across the board issue that needs a system upgrade to fix, since it appears it was the system upgrade that caused issue
