09-29-2022
04:19
05:39
09-29-2022
04:19
05:39
I have Charge 3 but I could not find its community. I need some help.
even in normal brightness mode I can not see the screen when I am outdoors. Only indoors in low light. I reinstalled but nothing happens.
09-29-2022 10:04
09-29-2022 10:04
I had that difficulty at first also, check to see if your fitbit is in sleep mode or dim. While wearing and checking statis I was changing dim mode by putting fitbit on sleep mode. Also my fitbit is hard to see it direct sunlight.
Best Answer11-02-2022 01:29
11-02-2022 01:29
n the Charge 3, swipe to the left until you see the "Settings" app. Tap on "Settings" and Brightness Settings should be your first option. Tap on "Brightness" to cycle through the options. You only have three options for brightness: dim, auto, and normal.
Regards,
Will
Best Answer11-02-2022 16:35
11-02-2022 16:35
Mine did this then eventually screen went blank. No fix
