06-17-2022
03:30
05:19
06-17-2022
03:30
05:19
I don't really notice how it started but my Fitbit screen suddenly got dim with no reason. It started from the edge of the screen now I can't barely see the menu at all. Can it be fixed or should I find a replacement gadget instead?
06-17-2022 05:17 - edited 03-16-2024 11:28
Hi there, @Lialialia. Welcome to the Community Forums. Thanks for the details provided in your post and the photo attached.
Please restart your Charge 3 as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
I've moved your post to the Other Charge Trackers board for organization purposes.
Hope that helps.
Best Answer06-17-2022 05:17 - edited 03-16-2024 11:28
Hope that helps.
Best Answer10-16-2022 12:05
10-16-2022 12:05
How about fitbit providing an update to fix the dimness of 5he screen ptoblem
Best Answer10-21-2022 02:34
10-21-2022 02:34
A long restart:
Connect the device to the charging cable.
While the device is plugged into the charging cable, press and hold the button down for 15 seconds.
The device turns on and shows a battery icon. The device turns off.
The device turns on and shows a progress bar and short vibrations occur.
Regards,
Will
