01-27-2020
02:34
17:42
01-27-2020
02:34
17:42
Hi,
I have had my fitbit for just over a year. The screen has on a number of occasions gone blank. I have alway managed to get the screen working by plugging it into the charger and holding the button.
Last night while trying to sync the fitbit the screen went off. I have been unable to get the screen back on since. I have tried repeatedly to do as I have done before but its not working. It still vibretes when I touch the button. I am also unable to sync it.
Has this happened to anyone else? Does anyone have any ideas on what I should do? I would really appreciate some help or advice about this!
01-28-2020 04:46 - edited 10-08-2024 09:02
Hi there @Sarahcwt, welcome to the Community Forums. Thanks for the details provided about your Charge 3's behavior. I appreciate you've taken the time to restart it prior to contacting us.
I've seen you contacted our Support Team after posting here but your chats got disconnected so I created a case to get you in contact with our Support team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Let me know if there's anything else I may do to help you in the meantime.
Best Answer01-28-2020 06:18
01-28-2020 06:18
Mine to help
Best Answer01-28-2020 08:38 - edited 02-23-2024 03:40
Hi there @Smcarroll, thanks for jumping in here.
If you're experiencing the same with your Charge 3, please restart it.
If the restart doesn't work, I suggest restarting your Charge 3 using the 15-second method:
In case that neither of the restarts work, please check in your Fitbit app if your Charge 3 is still syncing. If so,change the clock face to a different one to see if this brings back the display. Don't worry if you cannot see anything on the display by now, this process is done through the Fitbit app.
