01-02-2021
17:19
04:19
JuanJoFitbit
01-02-2021
17:19
04:19
JuanJoFitbit
As title says. I've done the whole spiel: remove device and re-add it, unpair and re-pair, reset, synch, etc. The screen no longer wakes when tapped and I have to press the side button to show screen. Obviously someone futzed with the sensitivity settings somewhere in the code and set it to zero or something. Being disabled and not being able to show the screen by tapping it is a PITA.
Also, which dim bulb in your employ thought it was a good idea to force us to set alarms on the watch and no longer let us use the app to organize them. That is the opposite of a 'quality of life' improvement and just plain dumb. Seriously, you have somehow managed to take an adequate product and make it worse all while failing to deliver on a 2+ year promise for an O2 meter.
Sincerely,
Not Happy
01-12-2021 04:19
01-12-2021 04:19
Hi @bandtCK2, welcome to our Fitbit Community. I totally understand how you feel about the screen issue that your Charge 3 is experiencing. By the way, thank you for trying to get this issue resolved before contacting our forums.
I'd like you to try one more workaround, which has been helpful for this issue. Please try a long restart. To do so, follow the steps below:
Keep me posted on the outcome.
Best Answer01-18-2021 13:39
01-18-2021 13:39
Best Answer01-20-2021 10:13
01-20-2021 10:13
Hi @bandtCK2, thank you for getting back. I'm glad to hear that you managed to get the issue resolved. Thank you for posting the update here.
Regarding the alarms issue, please make sure that you are following the steps listed in this help article when trying to set them. Also, make sure that your phone is running the most recent Fitbit app versions.
Let me know how it goes.
