06-16-2021
10:04
10:10
WilsonFitbit
06-16-2021
10:04
10:10
WilsonFitbit
My charge 3 has completely stopped tracking my sleep. Yes I have moved it up in my wrist and I am sleeping at least 6 hours a night
@Jezabelle72 Thank you very much for your reply!
Since the inconvenience has persisted, I'd recommend performing a long restart to your Charge 3, a long restart is different than the basic restart and you can complete it by following the instructions below:
If that doesn't help, my best recommendation is that you please reach out to our Support Team for further assistance. Note that you can contact them through chat or over the phone, but Phone wait times are longer than normal, so I recommend initiating a chat. Click here to get connected.
See you around.
Hello @Jezabelle72. Welcome to the community forums!
Thank you for the information and for the tips you've followed. At this time, I'd recommend performing a restart to your Charge 3 by following the instructions here: How do I restart my Fitbit device?
After the restart, please try to change the Sleep sensitivity setting. For example, if your sleep is now set to Normal, try to change it to Sensitive and test your Fitbit device. Take into consideration that normal mode can work well if you make significant movements like rolling over, your device records time spent awake. This setting is appropriate for most users. In sensitive mode, your device records nearly all movements as time spent restless or awake. This setting may be helpful if you wake up feeling tired even though your sleep history shows sufficient rest.
To change your sleep sensitivity setting:
I also recommend visiting the following link for tips and suggestions about Sleep: How do I track my sleep with my Fitbit device?
On a side note, if your Charge 3 experiences any syncing inconvenience, please check: Why won't my Fitbit device sync?
Hope this helps.
See you around.
