07-29-2019
18:57
10:55
07-29-2019
18:57
10:55
My Charge 3 two days ago stopped vibrating. When i pushed the side button, the vibrating that used to be there is not. I rebooted it, charged it fully and even tried to change the intensity for the vibrating and it still doesn't vibrate. I have gone as far as checking my phone for it being in silent mode, and it isn't. I have tried setting the silent alarm a few times today, it doesn't vibrate. When I get phone calls or text messages the screen lights up and notifies me of the message, but there is no vibrating. I am hoping that the vibration can be easily fixed as I use it for an alarm. Please let me know.
Thank you
07-30-2019 02:06
07-30-2019 02:06
Hi @Jccelmo It sounds as though the vibration motor has died. I have flagged a moderator to come and help you.
Helen | Western Australia
07-30-2019 11:48
07-30-2019 11:48
Hi @Jccelmo, nice to see you here again!
Thank you for all your effort in trying to solve this situation. As a last step, I kindly ask you to perform a long restart by following these steps:
Let me know if it worked!
@NellyG thanks for your help!
Best Answer07-30-2019 19:56 - edited 07-31-2019 17:16
Hello @LuciaFitbit,
Thank you for suggesting to do a reboot. I have performed the steps that you suggested twice. I plugged it in and it immediately went to the battery icon, pushed on the side button for 15 seconds, loaded the progress bar, then to a black screen and then to a happy face. Unfortunately even after completing the steps twice, the fitbit still does not vibrate.
I am hoping that there is a solution that can solve this problem.
07-31-2019 01:43
07-31-2019 01:43
contact support on the fitbit support page. I had a replacement sent for this fault
Best Answer08-01-2019 20:20
08-01-2019 20:20
Thank you for forwarding my issue to a moderator. I responded back to @LuciaFitbit about my results on the 30th but have not heard anything from them since. My fitbit is still not vibrating. Can you please advise on who I should contact at this point, so I can have my issue resolved.
Thank You
Best Answer08-02-2019 01:48
08-02-2019 01:48
Hi @Jccelmo You can wait for @LuciaFitbit to get back to you (I dont the days he works), but all moderators are usually good about coming back. Or you can contact Support directly - Fitbit Support
Best Answer08-02-2019 12:15
08-02-2019 12:15
@NellyG ... i'll wait to see if @LuciaFitbit gets back to me by Tuesday. Otherwise I will reach out to support.
Thank you for letting me know.
Best Answer08-10-2020 19:26
08-10-2020 19:26
I too am having this exact same issue. I use the timer function on my Charge 3 for work. If i miss the timer, things don't go too well for me (I am a Corrections Officer). I desperately need this issue to be resolved as i have tried everything that i have seen suggested but have had no luck. No vibrations for any sort of notification nor timer/alarms.
