06-15-2019
14:29
10:58
06-15-2019
14:29
10:58
Hi my charge 3 stopped working for no particular reason it has a slight vibration when I plug it in a brief picture of a smiley face will appear then disappear it has no charging display just a blank black screen.
If I have it off the charger and press the power button it vibrates also but nothing on the screen is it bricked or faulty goods is there a way out of this I tried all the steps posted still nothing the app does not see it in bluetooth ?? what next
You're very welcome @Eibhe. Please let me know if you need anything else. ![]()
We're here to help!
Best AnswerHi @Eibhe As you dont say what you have tried, then I may be repeating things you have already done.
Try:
Restart your tracker several times Restart your tracker
Try a Long Restart
CHARGE 3 LONG RESTART
Plug the device into the charging cable. While the device is plugged into the charging cable, hold the button down for 15 seconds. Remove your finger from button. Note: Device won't have a smiley face icon and should be off with a black screen. Remove the device from the charging cable. Plug the device into the charging cable again. The smiley face icon appears on the screen.
Try changing the clock face in the app
If none of them help please come back here.
Helen | Western Australia
Best AnswerHi Nelly sorry for the short detailed post but ya I have tried the steps you have posted too many times now with the same outcome, when I put it back on the charger I get the smiley face for a few seconds then black screen it is on and charged because anytime I press the power button it vibrates so I cant even default back the face because I've no display.
Best AnswerI have flagged a moderator to come and help you
Nice to see that you're digging into the Forums @Eibhe , let me give you a warm welcome to our Community. Thanks for the heads up @NellyG.
Thanks a lot for trying those steps to help your Fitbit. I'd recommend wait until you get the information from our team, as I've requested a case on your behalf. You should soon receive an email from Customer Support.
It's very important for us to have your thoughts about our products. Fitbit is always trying to provide great features and customer experience.
Let me know if you need anything else.
We're here to help!
Best AnswerUnfortunately, I am having a similar problem. I have also followed the steps and still, nothing has changed. There is no flashing light on my Fitbit anymore, the screen is black, and it will not connect to my phone. However, when I reboot it a smiley face will appear, but once it disappears, the screen is black again.
If you could reply with a resolution that would be great.
Regard,
Saoirse.
Welcome to the Community Forums @SaoirseC. Thanks for jumping in @Eibhe. My apologies for the delay.
Thanks for reporting this issue and for restarting your Fitbit but since it didn't solve the issue, I've requested to our support team to create a case on your behalf too. You should soon receive an email from customer support.
I'll be around in case that you need anything else.
Best AnswerHi my Fitbit Charge 3 is only 5 months old and it has just stopped working. I’ve tried all the troubleshooting tips from the other texts, but nothing helps. My screen is black and there is no vibration at all when I plug it into charger. Nothing happened to it, no fall no water. It just stopped working. Anybody any advice please
I am having this same issues. I've followed the directions to hook it to the charger & hold the button for 15 seconds, then remove from charger & then reconnect to charger with no avail. The "Best Answer" is not listed & when I click on "see best answer in original post" nothing happens. Can someone please help me since my Fitbit Charge 3 is not working at all.
Have you heard from the support team? I am having the same trouble. Restarted many times and no response. Very bummed
Best AnswerI also have had the same problem. 3 times! I bought a charge 3, a few months later it just stopped working. Went through all the fixes, customer support ended up sending me a replacement. About 2 months later, same thing. Another replacement. About 2 months later, same thing! I gave up. Really disappointed, I liked it but it was such an aggravation to go through the same exact defect 3 times in less than a year. Maybe it’s just something about the chemical makeup of my body?
Hello everyone. It's great to see you participating in the community forums.
@SunsetRunner Thank you very much for taking the time to provide your feedback! I'd like to let you know that my team is always working to enhance your experience and your feedback is a big part of that process.
In regards with your inquiry, I'd recommend visiting the following Wear and Care page to get more tips and information about how to take care of Fitbit devices.
See you around.
@SunsetRunner Thanks for sharing your comments! I'd like to mention that my team is always striving to improve the Fitbit experience and this is based on the feedback that we receive.
If you want to get more information about the Charge 4, I recommend visiting the following link:
https://staticcs.fitbit.com/content/assets/help/manuals/manual_charge_4_en_US.pdf and https://www.fitbit.com/global/us/products/find-your-fit for more details.
In the second link, you can find detailed information about all our Fitbit devices and find the device that better suits your needs.
See you around.
